I am running JIRA from war file on Win7.
1) Java 6
2) Tomcat 6
3) Jira 5
I installed JIRA yesterday. I was able to get into JIRA web application yesterday and was configuring JIRA, until I entered licence key and TomCat gave me PermGen space error.
So far I have been trying googleing for hours and trying stuff, but nothing seems to work. At the moment I have this snippet in my tomcat->catalina.sh file. Yes I tried putting this to setenv.sh(bat) file, but still same error. So far have not been able to get Jira up and running again.
JAVA_OPTS="-Djava.awt.headless=true -Dfile.encoding=UTF-8 -server -Xms1536m -Xmx1536m -XX:NewSize=512m -XX:MaxNewSize=512m -XX:PermSize=512m -XX:MaxPermSize=1024m -XX:+DisableExplicitGC"
Error:
2012-06-02 12:02:52,821 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\JIRA\home\plugins\.bundled-plugins\streams-api-5.1.0.jar (1337537820000) created 2012-06-02 12:02:52,828 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\JIRA\home\plugins\.bundled-plugins\streams-core-plugin-5.1.0.jar (1337537822000) created 2012-06-02 12:02:52,839 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\JIRA\home\plugins\.bundled-plugins\streams-inline-actions-plugin-5.1.0.jar (1337537822000) created 2012-06-02 12:02:52,845 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\JIRA\home\plugins\.bundled-plugins\streams-jira-inline-actions-plugin-5.1.0.jar (1337537822000) created 2012-06-02 12:02:53,068 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\JIRA\home\plugins\.bundled-plugins\streams-jira-plugin-5.1.0.jar (1337537820000) created 2012-06-02 12:02:53,083 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\JIRA\home\plugins\.bundled-plugins\streams-spi-5.1.0.jar (1337537822000) created 2012-06-02 12:02:53,093 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\JIRA\home\plugins\.bundled-plugins\streams-thirdparty-plugin-5.1.0.jar (1337537822000) created 2012-06-02 12:02:53,113 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\JIRA\home\plugins\.bundled-plugins\workflow-designer-plugin-2.5.5.jar (1337537818000) created 2012-06-02 12:03:01,127 Spring executor 1 INFO [plugins.monitor.rrd4j.RrdUpdater] Reusing existing RrdDb: C:\JIRA\home\monitor\ConnectionPoolGraph.rrd4j 2012-06-02 12:03:01,220 Spring executor 1 INFO [plugins.monitor.rrd4j.RrdUpdater] Reusing existing RrdDb: C:\JIRA\home\monitor\DatabaseReadWritesGraph.rrd4j 2012-06-02 12:03:01,319 Spring executor 1 INFO [jira.plugins.monitor.MonitoringScheduler] Scheduling metrics collector to run every 10000ms... 2012-06-02 12:03:50,998 Spring executor 4 WARN [beans.factory.support.DefaultListableBeanFactory] FactoryBean threw exception from getObjectType, despite the contract saying that it should return null if the type of its object cannot be determined yet java.lang.OutOfMemoryError: PermGen space
Notice the Tomcat stops for 49 seconds on "Scheduling metrics collector to run every 10000ms...".
Instead of changing Initial Memory Pool and Maximum memory pool in tomcat6w, add following line to Java Options in Java tab:
-XX:MaxPermSize=512m
This solution works when using Tomcat as service.
Can you go to Administration > System Info after JIRA is started and see if the memory change is effective or not? For example, if you are running as a service, changes to setEnv.sh won't be effective.
You mean, it is not even starting up? I have seen permgen errors mostly when you try to do stuff in JIRA. Sorry, that doesn't seem to be the case here.
You should be able to see the memory allocated in the startup logs too, if you get that far!
Not sure where to see if memory change is effective from Admin -> System, is that Linux? I have tried running both, service and from startup. My tomcat6w GUI has settings under Java tab : "Initial memory pool : 256 " , "Maximum memory pool : 512 ". Both still give me PermGen error.
Did you try increasing the memory for Jira's service yet? This link talks about the available memory for a service, but it also the same place where you need to set permGen memory as well.
"Windows Service
See the guide Increasing JIRA Memory. Scroll to the part of the discussing Permanent Generation Space. Pay specific attention to where to apply the settings especially if you are using a Windows Service, and follow the instructions for changing the PermGen Space Parameters rather than the Heap Space Parameters."
https://confluence.atlassian.com/display/JIRA044/Increasing+JIRA+Memory
Look first line, I am running on Windows 7. My tomcat6w GUI has settings under Java tab : "Initial memory pool : 256 " , "Maximum memory pool : 512 ". That should increase JIRA memory right?
You need to modify the MaxPermSIze.
