JIRA list custom fieldis
Dmitriy Kalabin July 10, 2017
I need to put a condition on the user field in the post function. The custom field has a format list, i.e. The user chose the value and the function should look at this condition. Tell me how it can be done? How does getCustomFieldValue return a field of type list?
it's not working:
Is1 = issue.getCustomFieldValue(customField)
if Is1 == 'test1':
Nic Brough -Adaptavist-
July 11, 2017
A "condition" has a very specific meaning in JIRA - it happens *before* a post function and *only* tells the system whether the current user may use the transition or not.
I am assuming by "field of type list", you're looking at a field that is a single-select list.  getCustomFieldValue will return an object representing the current selected, not a simple string.
You'll probably need something more like
if ( "test1".equals(Is1.getName()))
