JIRA mention does not show up on Confluence's workbox
John Yeuk Hon Wong November 12, 2014
I followed https://confluence.atlassian.com/display/DOC/Configuring+Workbox+Notifications but I still cannot receive mention notification on Confluence's workbox. I've enabled all three authentication methods (trusted channel, oauth, and basic access).
Is there a way to test the mention capability via some API to know what is failing? The log doesn't show much...other than leading me to https://confluence.atlassian.com/display/JIRAKB/Application+Link+authentication+fails+due+to+bad+URL+signature
Rodrigo Girardi Adami
November 13, 2014
Hi John,
Maybe the problem in this case is having all authentication enabled. This is not recommend actually.
I recommend to remove the app links from Confluence and JIRA and recreate them using only a OAuth which is more reliable auth now for the latest apps.
Then check if both apps can communicate as expected and test again. I hope this helps.
Rodrigo
John Yeuk Hon Wong November 13, 2014
Thanks. I actually tried this approach but still have no luck. I will try again. Thanks
John Yeuk Hon Wong November 16, 2014
@Rodrigo Adami Still doesn't work. Thoughts on testing the connect at API level? Thanks.
