This issue is on and off. I followed the below troubleshooting..
Checked the Email Request under Applications>> Service Desk
Test gives me "
No problems found with email settings configuration. Successfully connected to the specified email server. |
Logs says ServiceRunner Messaging Error when MailPullerWorker pulls emails from help@abc.com: Couldn't connect to host, port: outlook.office365.com, 993; timeout 50000
JIRA-Bootstrap Updated mail connection id 5 with parameters help@abc.com help@abc.com outlook.office365.com imaps 993
ERROR [] Caesium-1-2 anonymous Messaging Error when MailPullerWorker pulls emails from help@abc.com: A3 BAD User is authenticated but not connected.
Here is my configurations details. We have 4 POP / IMAP Mail Servers listed in Incoming Email(it has help@abc.com details with different server name and username). Attached Image 1
That specific error message is known to happen when Jira is using IMAP with a shared mailbox on office 365. There is a KB on that error in: A3 BAD User is authenticated but not connected error message when using JIRA with Office365
From that KB:
Cause
- JIRA does not support IMAP integrated with a Shared Mailbox. This feature suggestion has been closed as there are no current plans to build it:
JRASERVER-30688 - IMAP login to a shared mailbox RESOLVED
Workaround
Use POP3 instead:
Protocol: SECURE_POP
Host: outlook.office365.com
Port: 995
Username: licenseduser@mydomain.com\sharedmailboxalias
Password: (licensed user password)
I hope this helps.
Hi Frank,
Are you talking about Mail Handler or normal Jira Service Desk email configuration? Because that looks like a mail handler to me, which usually does not have anything to with how Jira Service Desk mail is configured, in fact I would not recomend configuring both of them for the same project...
Jira is a bit delicate when working with mails. Make sure your Jira installation can reach the mailbox and try first with a normal email (even your own email would work) before trying shared accounts or mailbox. I usually find it works better with a single email in the same domain as the one configure for sending mails.
