JIRA reports
Tim Schmidt November 26, 2014
How can I export the JIRA Reports (like average age report) into a file with the values listed and parted with ";"?
Cheers!
Pablo Beltran
December 30, 2015
SQL for JIRA allows to perform JQL as SQL statements. Then you can use a lot of JDBC tools to export your JIRA data with the required output format.
Tim Schmidt December 1, 2014
but how exactly do I export those? I can't find the option to do this.
Cheers!
Luciano Fagundes
November 26, 2014
Tim
You can export into an Excel format (xls), open it using Excel or any other spreadsheet application that supports this format and then save into CSV format.
Cheers
L.F
