I have made couple of sprints long plan. Now there are leaked items which make a collateral effect on the following sprints. What would be the best way to re-plan (tooling-wise) without needing to go thru ticket by ticket and move them accordingly.
Some kind of batch operation to move all the tickets e.g. +1 sprint?
I have Advanced roadmap in use, if that helps.
To be honest this should be actively replanned by the Product Owner, not just shifted by a tool
Actually, it should be done by the team, not PO. I am just seeking options to make that easier.
Well Product Backlog Prioritisation at a chunky level = PO, the team needs to agree into inclusion in each Sprint backlog and breakdown if they wish into tasks (assuming we're doing Scrum) right? :)
When closing a Sprint Jira will automatically give the prompt on what to do with the hanging over stories, and in the backlog view you can multi-select and move tickets.
Well, you were talking about replanning, not prioritization. I agree PO is to be making the prioritization in the end (using team input).
Closing sprint will prompt yes, and you can choose to move the items, but I was more after way to move selected items distributed several sprint e.g. +one sprint as there is collateral effect.
