×We are using JIRA v7.2.15
I have never used JIRA, walked through several videos over the past several hours and I no closer to getting us started. Hoping you can help! We need to do the following:
We need make our team projects private in JIRA
Under our Team Name which doubles as our Project Name in JIRA
I need to:
1) list several automation projects we have going on
2) Build a Product Backlog for each
3) Road Maps for each
Our JIRA instance shows the following in the left column:
Team Name
Scrum
Backlog
Acive Sprints
Releases
Reports
Issues
etc.
And at the top:
Dashboard Projects Issues Boards Portfolio ezBI and WorkBoard
Hi @AChance
Try this.
Option 1
Option 2
If the projects are independent from each other then different project and separate project will work better.
Since you have Portfolio installed as well. You can also use it to create a plan with all the projects. Portfolio will have filters on top for you and you can use it to create a roadmap and dependencies.
Ravi
Ravi that's exactly what I needed, thank you!
Learn more
