JIRA won't start after installing and configuring SSL certificate (Additional Question)
Ruedi Neff
October 22, 2017 edited
Hi
We're running Version 7.2.4 of Jira and have a similar problem like your case (639260):
https://community.atlassian.com/t5/Jira-questions/JIRA-won-t-start-after-installing-and-configuring-SSL/qaq-p/639260
Is it possible that this can occur in version 7.2.4 and Tomcat 8.0.33 already?
Thanks for your reply.
Kind regards
Steven de Groot
October 23, 2017
Hi Ruedi,
This doesn't seem to be the same issue. In JIRA 7.3 the tomcat version that is used is 8.5 which doesn't support the protocol that is still supported in tomcat 8.0 (which is still used for your version 7.2).
Please see below;
connectors in 8.0
org.apache.coyote.http11.Http11Protocol - blocking Java connector
org.apache.coyote.http11.Http11NioProtocol - non blocking Java NIO connector
org.apache.coyote.http11.Http11Nio2Protocol - non blocking Java NIO2 connector
org.apache.coyote.http11.Http11AprProtocol - the APR/native connector.
connectors in 8.5
org.apache.coyote.http11.Http11Protocol doesn't exist any more in 8.5
I would recommend going though the official instructions which can be found here: https://confluence.atlassian.com/adminjiraserver071/running-jira-applications-over-ssl-or-https-802593051.html
Register now
