JIRAISSUE table column descriptions
Nagappan Murugappan March 10, 2021
Hello
I would like to know where can i find description of JIRA table columns, for example there is a column called RESOLUTION in JIRAISSUE table, i could find values like 10000 or 10001 etc, but if i want to know description for these values where can i find them.
Version i am referring to is (server version)
  • v8.13.1
thank you
Hana Kučerová
Hi @Nagappan Murugappan ,
resolutions are in resolution table:
select id, pname, description from resolution
Thanks a lot Hana.
Nic Brough -Adaptavist-
March 10, 2021
Stop reading the database, it's the worst possible way to look at Jira data.
Hi Nic
Thanks for your feedback, its not for looking at the data, but based on resolution and resolution dates, we do create certain customized reports.
Register today
