JIra Capture : can different users work on different test sessions at same time ?
Jean-Sebastien (GA)
From the dcumentation https://confluence.atlassian.com/display/CAPTURE/Working+with+Sessions#WorkingwithSessions-AssigningSessions, "For each user, only one session can be active at one time."
So, I get that only one test session can be active on the user browser.
But what if I want to start several test sessions, dispatched to different users ?
It seems that only one test session is active in the whole system, which I consider as a limitation.
I define 2 test sessions, A & B, I ask Bob and Jim to work on A, while I ask Sarah and Cindy to work on B, at the same time.
It seems it is impossible to do this, because I can't start two sessions ! starting a second one pauses the first one.
So how can I have my teammates split into 2 groups, each of them working on two different sessions ?
Peter Van de Voorde
June 24, 2014
Hi Jean-Sébastien,
Did you try to start the different sessions or did your team mates start the sessions?
Best regards,
Peter
Jean-Sebastien (GA)
Hi Peter, thanks for answering :)
I did try to start the different sessions. I start the first one, then when start the second one, the first one automatically switch to paused.
Peter Van de Voorde
June 24, 2014
You as a user can only start one session at a time, so that's normal.
In your example you should let Bob start test session A and Sarah test session B.
Then Jim and Cindy can join in.
That should normally work.
Best regards,
Peter
Jean-Sebastien (GA)
All right Peter, I will play with that :)
thanks again !
