I want to have an overview of the jira project configuation.
So a list of all project names, leads and then which workflow scheme, issuetype scheme, screen scheme and permission scheme they are using.
can somebody please help me with that?
try
SELECT P.pkey, p.lead, p.projecttype, nas.ASSOCIATION_TYPE,
nas.SINK_NODE_ENTITY,
NotificationScheme,
PermissionScheme,
WorkflowScheme,
IssueTypeScreenScheme,
FieldLayoutScheme
FROM project p,
(select source_node_id, max(ASSOCIATION_TYPE) as association_type, max(sink_node_entity) as sink_node_entity, max(nid), max(nname) as NotificationScheme ,
max(pid), max(pname) as PermissionScheme,
max(wid), max(wname) as WorkflowScheme,
max(iid), max(iname) as IssueTypeScreenScheme,
max(fid), max(fname) as FieldLayoutScheme from nodeassociation
-- left join cwd_user on lead = user_name
left outer join ( select max(id) as nid , name as nname from notificationscheme group by name) ns on sink_node_id = ns.nid and sink_node_entity = 'NotificationScheme'
left outer join ( select max(id) as pid, name as pname from permissionscheme group by name) ps on sink_node_id = ps.pid and sink_node_entity = 'PermissionScheme'
left outer join ( select max(id) as wid, name as wname from workflowscheme group by name) ws on sink_node_id = ws.wid and sink_node_entity = 'WorkflowScheme'
left outer join( select max(id) as iid, name as iname from IssueTypeScreenScheme group by name) itss on sink_node_id = itss.iid and sink_node_entity = 'IssueTypeScreenScheme'
left outer join ( select max(id) as fid, name as fname from FieldLayoutScheme group by name) fls on sink_node_id = fls.fid and sink_node_entity = 'FieldLayoutScheme'
where association_type = 'ProjectScheme'
group by source_node_id) nas
where p.id = nas.source_node_id
order by pkey
no more time to refine further :-)
actually that looks wrong. but out of time for today
Hi
did you run it ?
what else would you like to tweak?
@Tom Lister Hi Tom,
That's a great query, thanks :)
Would it be possible to additionally show IssueTypeScheme? Currently only IssueTypeScreenScheme is shown.
Good question. It isn't at all obvious where that data is stored. Not in the same place as the other scheme nodes as far as I can see.
I'll think about it for a while :-)
Tom
I think that this will give you all the names
select * from fieldconfigscheme where FIELDID = 'issuetype'
and it's connected with projects thru configurationcontext table where customfield = 'issuetype'
Hi @Tom Lister
One more thing, when running this query I get all projects except those using Default schemes.
Any idea how those can be included?
Regarding IssueTypeScheme, here is SQL that gets that information
with SQL you can try
ns.name as NotificationScheme,
ps.name as PermissionScheme,
ws.name as WorkflowScheme,
itss.name as IssueTypeScreenScheme,
fls.name as FieldLayoutScheme
FROM project p, nodeassociation nas
left join notificationscheme ns on sink_node_id = ns.id and sink_node_entity = 'NotificationScheme'
left join permissionscheme ps on sink_node_id = ps.id and sink_node_entity = 'PermissionScheme'
left join workflowscheme ws on sink_node_id = ws.id and sink_node_entity = 'WorkflowScheme'
left join IssueTypeScreenScheme itss on sink_node_id = itss.id and sink_node_entity = 'IssueTypeScreenScheme'
left join FieldLayoutScheme fls on sink_node_id = fls.id and sink_node_entity = 'FieldLayoutScheme'
and source_node_entity = 'Project'
order by pkey
This is a good start but....I get this as an outcome.... Isn't it possible to get one row per project?
pkeyleadprojecttypesink_node_entitynotificationschemepermissionschemeworkflowschemeissuetypescreenschemefieldlayoutscheme.
AAS | ano | software | NotificationScheme | Default Notification Scheme | null | null | null | null |
AAS | ano | software | IssueTypeScreenScheme | null | null | null | AAS: Kanban Issue Type Screen Scheme | null |
AAS | ano | software | WorkflowScheme | null | null | AAS: Software Simplified Workflow Scheme | null | null |
AAS | ano | software | PermissionScheme | null | Default software scheme | null | null | null |
This is Toms original query, but with a few fixes:
NotificationScheme,
PermissionScheme,
WorkflowScheme,
FieldLayoutScheme
FROM project p,
(select source_node_id, max(ASSOCIATION_TYPE) as association_type, max(sink_node_entity) sink_node_entity, max(nid) nid, max(nname) as NotificationScheme ,
max(pid) pid, max(pname) as PermissionScheme,
max(wid) wid, max(wname) as WorkflowScheme,
max(iid) IID, max(iname) as IssueTypeScreenScheme,
max(fid) FID, max(fname) as FieldLayoutScheme from nodeassociation
group by source_node_id) AS nas
order by pkey
Thanks @Tom Lister! I tweaked it to produce the scheme result in a single column:
SELECT
p.pname, p.pkey,
nas.SINK_NODE_ENTITY as 'SchemeType',
CAST(
CASE
WHEN sink_node_entity = 'PermissionScheme' THEN ps.name
WHEN sink_node_entity = 'NotificationScheme' THEN ns.name
WHEN sink_node_entity = 'WorkflowScheme' THEN ws.name
WHEN sink_node_entity = 'IssueTypeScreenScheme' THEN itss.name
WHEN sink_node_entity = 'FieldLayoutScheme' THEN fls.name
END AS varchar) as 'SchemeName'
FROM
left join notificationscheme ns on nas.SINK_NODE_ID = ns.id and nas.SINK_NODE_ENTITY = 'NotificationScheme'
left join permissionscheme ps on nas.SINK_NODE_ID = ps.id and nas.SINK_NODE_ENTITY = 'PermissionScheme'
left join workflowscheme ws on nas.SINK_NODE_ID = ws.id and nas.SINK_NODE_ENTITY = 'WorkflowScheme'
left join IssueTypeScreenScheme itss on nas.SINK_NODE_ID = itss.id and nas.SINK_NODE_ENTITY = 'IssueTypeScreenScheme'
left join FieldLayoutScheme fls on nas.SINK_NODE_ID = fls.id and nas.SINK_NODE_ENTITY = 'FieldLayoutScheme'
WHERE
p.id = nas.SOURCE_NODE_ID and nas.SOURCE_NODE_ENTITY = 'Project'
ORDER BY
p.pkey, nas.SINK_NODE_ENTITY
Hi Maarten,
Thank you for your question.
I can confirm that the Project Configurator add on has a Used by report feature which will allow you to see where configuration objects are referenced inside of Jira and this may help you to satisfy your requirement.
You can see further details on how the Used by report works in the documentation located here.
If this response has answered your question can you please mark it as accepted so that other users searching for a similar question can see that this is a correct answer.
Kristian
Unfortunatly this is not exactly where I am looking for. We have a list of projects and we want to identify which configurations they are using (if they are using a template then they are complient to certain regulations) its a combination of workflow scheme (transitions will make things filled in and force that someone with a project role PO approve things) issuetype scheme (makes sure that the issuetypes are matching the workflow) and screen scheme (makes sure the information that is triggered via workflow is available) and the permission scheme that make that only a certain role can create issues as an approved change requestor) If I do it via the used by report functionalitiy its still a lot of work.
you can check Project name > project settings > summary.
there you can find the overview of your project with all the required details
This is a very time consuming thing.... if you have more then 500 projects....
