According to https://confluence.kepler-rominfo.com/display/JJUP30/Supported+fields+and+graphic+elements
resolved field is supported by SIL language.
When I tried to use that value e.g.
I got variable is not defined
Maybe somebody knows how to solve it?
You're actually looking for the actual fields, accessing them and managing their value. The complete list(without any additional fields, coming from plugins like JJUPIN Agile) is here: https://confluence.kepler-rominfo.com/display/SIL30/Variable+Resolution
The page you've found is the supported pieces of the screen to interact with them(showing, hiding, adding mouse events), like Attachments or the comments section, which is part of the Live Fields feature.
You're actually looking for the resolutionDate field instead of resolved.
Hope this helps,
Silviu
Thank you very much!
Silviu, thanks for the answer. However, resolved was an alias before . Do not know what to do right now, if I should add it or not. Until now, nobody complained.
Should work. Any chance to see the actual error in the log? Are you on the create screen (where the key is not defined) ?
It is on the create issue screen.
Firstly I assign ticket number to test it:
string key = "TEST-591";
The 18th line is:
runnerLog(%key%.#{resolved});
Log is:
2016-08-02 10:52:53,938 http-bio-8080-exec-18 ERROR partyme 652x61664x1 an4hyh 158.166.202.91 /rest/keplerrominfo/commons/latest/utils/check [plugins.commons.rest.UIUtils] Exception: [SIL Error on line: 18, column: 1] Expected parameter list to match any of [[STRING], [STRING, NUMBER], [STRING, NUMBER, STRING]] but we got [null] parameters [SIL Error on line: 18, column: 16] Invalid accessor for types [BOOLEAN[], JLdapUserAttribute[], STRING[][], NUMBER, JIssueLink[], JWorklog[], STRING[], INTERVAL[], INTERVAL, JIssue, JVersion, DATE, NUMBER[], DATE[], JLdapUserStruct, JComment, JIssueLink, JLdapUserAttribute, SystemResult, JUser, JWorklog, STRING, JProject, BOOLEAN, JComponent, JLdapUserStruct[]] com.keplerrominfo.sil.lang.grammar.SilParseException: [SIL Error on line: 18, column: 1] Expected parameter list to match any of [[STRING], [STRING, NUMBER], [STRING, NUMBER, STRING]] but we got [null] parameters [SIL Error on line: 18, column: 16] Invalid accessor for types [BOOLEAN[], JLdapUserAttribute[], STRING[][], NUMBER, JIssueLink[], JWorklog[], STRING[], INTERVAL[], INTERVAL, JIssue, JVersion, DATE, NUMBER[], DATE[], JLdapUserStruct, JComment, JIssueLink, JLdapUserAttribute, SystemResult, JUser, JWorklog, STRING, JProject, BOOLEAN, JComponent, JLdapUserStruct[]] at com.keplerrominfo.sil.lang.SILInterpreter.throwIfErrors(SILInterpreter.java:212) at com.keplerrominfo.sil.lang.SILInterpreter.check(SILInterpreter.java:134) at com.keplerrominfo.jira.commons.silrunner.UnifiedSilRunner.verify(UnifiedSilRunner.java:179) at com.keplerrominfo.jira.plugins.commons.rest.UIUtils.isSILValid(UIUtils.java:112) at com.keplerrominfo.jira.plugins.commons.rest.UIUtils.checkSil(UIUtils.java:66) <+2> at java.lang.reflect.Method.invoke(Unknown Source) at com.sun.jersey.spi.container.JavaMethodInvokerFactory$1.invoke(JavaMethodInvokerFactory.java:60) <+13> (AbstractResourceMethodDispatchProvider.java:205) (ResourceJavaMethodDispatcher.java:75) (HttpMethodRule.java:288) (RightHandPathRule.java:147) (ResourceClassRule.java:108) (RightHandPathRule.java:147) (RootResourceClassesRule.java:84) (WebApplicationImpl.java:1469) (WebApplicationImpl.java:1400) (WebApplicationImpl.java:1349) (WebApplicationImpl.java:1339) (WebComponent.java:416) (ServletContainer.java:537) at com.atlassian.plugins.rest.module.RestDelegatingServletFilter$JerseyOsgiServletContainer.doFilter(RestDelegatingServletFilter.java:178) <+1> (ServletContainer.java:795) at com.atlassian.plugins.rest.module.RestDelegatingServletFilter.doFilter(RestDelegatingServletFilter.java:73) <+16> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (ServletFilterModuleContainerFilter.java:77) (ServletFilterModuleContainerFilter.java:63) (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70) (RestServletUtilsUpdaterFilter.java:26) (RestServletUtilsUpdaterFilter.java:40) (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70) (ContextFilter.java:25) (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70) at com.atlassian.mywork.client.filter.ServingRequestsFilter.doFilter(ServingRequestsFilter.java:37) <+3> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70) at com.atlassian.plugins.cors.CorsFilter.doFilter(CorsFilter.java:65) <+3> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70) at com.atlassian.prettyurls.filter.PrettyUrlsSiteMeshFixupFilter.doFilter(PrettyUrlsSiteMeshFixupFilter.java:36) <+3> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70) at com.atlassian.prettyurls.filter.PrettyUrlsDispatcherFilter.doFilter(PrettyUrlsDispatcherFilter.java:60) <+3> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70) at com.atlassian.prettyurls.filter.PrettyUrlsSiteMeshFilter.doFilter(PrettyUrlsSiteMeshFilter.java:92) <+3> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70) at com.atlassian.prettyurls.filter.PrettyUrlsMatcherFilter.doFilter(PrettyUrlsMatcherFilter.java:56) <+3> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70) at com.atlassian.labs.botkiller.BotKillerFilter.doFilter(BotKillerFilter.java:36) <+18> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (ServletFilterModuleContainerFilter.java:77) (ServletFilterModuleContainerFilter.java:63) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (AccessLogFilter.java:106) (AccessLogFilter.java:90) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (XsrfTokenAdditionRequestFilter.java:54) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (ChainedFilterStepRunner.java:87) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (IteratingFilterChain.java:46) (DelegatingPluginFilter.java:70) at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(PrettyUrlsCombinedMatchDispatcherFilter.java:61) <+22> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (ServletFilterModuleContainerFilter.java:77) (ServletFilterModuleContainerFilter.java:63) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (SecurityFilter.java:239) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (TrustedApplicationsFilter.java:100) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (BaseLoginFilter.java:172) (JiraLoginFilter.java:70) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (IteratingFilterChain.java:46) (DelegatingPluginFilter.java:70) (OAuthFilter.java:79) (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70) at com.atlassian.plugins.rest.module.servlet.RestSeraphFilter.doFilter(RestSeraphFilter.java:40) <+3> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70) at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(PrettyUrlsCombinedMatchDispatcherFilter.java:61) <+9> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (ServletFilterModuleContainerFilter.java:77) (ServletFilterModuleContainerFilter.java:63) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (AbstractJohnsonFilter.java:71) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) at org.tuckey.web.filters.urlrewrite.RuleChain.handleRewrite(RuleChain.java:176) at org.tuckey.web.filters.urlrewrite.RuleChain.doRules(RuleChain.java:145) at org.tuckey.web.filters.urlrewrite.UrlRewriter.processRequest(UrlRewriter.java:92) <+10> (UrlRewriteFilter.java:394) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (GzipFilter.java:88) (GzipFilter.java:59) (JiraGzipFilter.java:55) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (IteratingFilterChain.java:46) (DelegatingPluginFilter.java:70) at com.atlassian.analytics.client.filter.JiraAnalyticsFilter.doFilter(JiraAnalyticsFilter.java:40) at com.atlassian.analytics.client.filter.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:32) <+3> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70) at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(PrettyUrlsCombinedMatchDispatcherFilter.java:61) <+6> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (ServletFilterModuleContainerFilter.java:77) (ServletFilterModuleContainerFilter.java:63) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) at eu.europa.ec.digit.citnet.seraph.EcasSeraphFilter.doFilter(EcasSeraphFilter.java:81) <+28> (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (ChainedFilterStepRunner.java:87) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (AbstractCachingFilter.java:33) (AbstractHttpFilter.java:31) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (AbstractEncodingFilter.java:41) (AbstractHttpFilter.java:31) (PathMatchingEncodingFilter.java:45) (AbstractHttpFilter.java:31) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (JiraStartupChecklistFilter.java:79) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (MultipartBoundaryCheckFilter.java:41) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (ChainedFilterStepRunner.java:87) (JiraFirstFilter.java:60) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (StandardWrapperValve.java:220) (StandardContextValve.java:122) (AuthenticatorBase.java:501) at eu.cec.digit.ecas.client.j2ee.tomcat.EcasAuthenticator.invoke(EcasAuthenticator.java:548) <+8> (StandardHostValve.java:171) (ErrorReportValve.java:103) (StandardEngineValve.java:116) (AccessLogValve.java:950) (CoyoteAdapter.java:408) (AbstractHttp11Processor.java:1070) (AbstractProtocol.java:611) (JIoEndpoint.java:316) at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61) at java.lang.Thread.run(Unknown Source)
Ok. Found the problem. Somehow we forgot this alias in between the 2.5 and 3.0. Use resolutionDate instead.
