JJupin v3.0.7
While developing another script I tried to print to the log using a simple print command.
string[] complist; number i; number marraySize; marraySize = arraySize(components); for(i=0; i < marraySize; i = i + 1) { if(components[i] == "Tempo") { watchers = addElementIfNotExist(watchers, "dt02765"); watchers = addElementIfNotExist(watchers, "dt202280"); } } print("Name");
What I get in the log is this over and over:
2016-04-14 11:17:08,034 http-bio-8080-exec-22 ERROR dt84658 677x589x1 x5a9l3 10.142.150.21 /secure/WorkflowUIDispatcher.jspa [commons.ivm.routines.UserFullNameRoutine] Empty username provided.
2016-04-14 11:17:08,136 http-bio-8080-exec-22 ERROR dt84658 677x589x1 x5a9l3 10.142.150.21 /secure/WorkflowUIDispatcher.jspa [commons.ivm.routines.UserFullNameRoutine] Empty username provided.
The script works, but the print("name"); function does not.
I have already added under Logging and Profiling:
com.keplerrominfo | INFO |
Any Ideas?
HI Craig,
Depending on what kind of print you need, you can use print, logPrint or runnerLog routines.
print routine puts the output in the /catalina.out
logPrint puts the output in jira_home/atlassian-jira.log
runnerLog puts the output in the gadget's console (from JJUPIN/SER)
Hope this helps,
Alexandra
Thank you for your response, but your docuementation says different. Besides I have used the print() function in the past and it worked. Just let me know if it is broken or not so I do not waste time.
From your documentation:
https://confluence.kepler-rominfo.com/display/JJUPIN/Configure+JIRA+Logging
Configure JIRA Logging
JIRA uses Log4J as a logging system. We're interested in output messages produced by our plugins so you will need to configure logging.
Note
IconIf you do not perform this configuration step, some routines such as print() will not output messages.
You are looking for logPrint routine
