JQL BEFORE predicate and relative formats
angel
I'm trying to find issues in certain status for which the transition took place before X hours/minutes etc.
status = "STATUS ABC" and status changed to "STATUS ABC" BEFORE -2h
The syntax seems syntactically valid but I don't get the expected results. Any ideas?
Nic Brough -Adaptavist-
August 4, 2014
Dates and times are numbers. So try greater and less than symbols < and >. I think your clause will be status changed to x > -2h ( that means "a time greater than two hours ago" or "in the last two hours"
angel
Nic,
the comparison operators "<" , " >", etc. are not valid for the "CHANGED" operator, only BEFORE or AFTER
August 4, 2014
Bother, sorry, I forgot that, I was looking just at the date/time element, it had just come up at the office.
Before and after only accept absolute date/time as far as I know.
