JQL Find Issues by Epic
Brian Oconnell July 1, 2019
How can I query issues by the Epic to which they belong?
Specifically, this is to insert in the "Insert JIRA Issue/Filter" macro in Confluence.
This should be super basic but I can't find documentation anywhere.
Sebastian Krzewiński
Hi @Brian Oconnell
To list all issues in specific epic please use "Epic Link" = EPIC_KEY
Seba
Femi
November 4, 2019
How do I find the Epic key or ID that is compatible with a JQL query. The Epic Name and link does not work in the query
Like Alisha Taubner likes this
Ingo Krug
February 24, 2020
I had the same problem several times. Using "epic link" = EPIC_KEY did not work in a query.... (p.e. for quick filters in BigPicture...).
Brian Oconnell July 2, 2019
Thank you.  That worked when I waited for auto-fill to populate the field name, but not when I copied and pasted it.
