JQL Query Count Number of Times an Issue Has Been Rejected
Chris Mazzochi
Given an issue, can I write a JQL query that will return the number of times an issues has been rejected?
I'd appreciate it.
Chris Mazzochi
Tarun Sapra
Hello @Chris Mazzochi
Form your query it seems "Rejected" is a status. Basically JQL is used to fetch issues but it can't run aggregation/analytics on the data. You can query issue history using "WAS" / "During" / Changed keywords but it won't retrieve you the exact count.
You will need add-ons to achieve this.
If you have script runner then you can have a scripted field which returns this value.
def theStatus = 'Rejected'
def changeItems = ComponentAccessor.changeHistoryManager.getAllChangeItems(issue)
def transitionsCount = changeItems?.findAll{it.field == 'status' && it.getTos().values().contains(theStatus)}.size()
return transitionsCount as Double
Chris Mazzochi
Thank you.  I will try this.
Chris Mazzochi
I am querying this data from Klipfolio though.
Alexey Matveev
December 22, 2017
It is not possible. JQL queries can return only issues, they can not return number of times.
Chris Mazzochi
How about the number of rejections per user for a given time period?
Nic Brough -Adaptavist-
December 22, 2017
JQL finds issues.  It does not report on them.
Alexey Matveev
December 22, 2017 edited
You can create a scripted field as @Tarun Sapra suggested. You would need an additional add-on for it and do some coding but it is not connected to JQL. JQL just finds issues but  you can provide information about the issues in custom fields.
Chris Mazzochi
Thank you guys.  I will try the add-on/scripted field route.
Chris Mazzochi
I forgot to mention that I am running these queries from Klipfolio.  So the add on solution doesn't apply.  I think the add on is for JIRA.
Learn more
