JQL: difference between resolution = and resolution changed to?
Ben Clark
July 26, 2013
What is the difference between "resolution =" and "resolution changed to" when running JQL.
project = KSENROLL AND resolution = Fixed AND fixVersion = M7
Returns 1287 Issues
project = KSENROLL AND resolution changed to Fixed AND fixVersion = M7
Returns 1330
Ben
RambanamP
July 26, 2013
The "CHANGED" operator is used to find issues that have a value which had changed for the specified field.
This operator has the following optional predicates:
  • AFTER "date"
  • BEFORE "date"
  • BY "username"
  • DURING ("date1","date2")
  • ON "date"
  • FROM "oldvalue"
  • TO "newvalue"
check the following document to get knowledge on advace searching
https://confluence.atlassian.com/display/JIRA/Advanced+Searching
Eva
July 26, 2013
the former one is where the resolution is currently set to fixed. The latter one is any tickets that has had resolution as "fixed" but could now have a different value.
Karl Puder
July 29, 2013
You can also see by example what characterizes the difference by trying these two queries:
project = KSENROLL AND resolution changed to Fixed AND fixVersion = M7 AND NOT resolution = Fixed
project = KSENROLL AND resolution = Fixed AND fixVersion = M7 AND NOT resolution changed to Fixed
Ben Clark
July 30, 2013
ah, Thank you!
