*Scenario:* I have an initiative with 5 epics and a bunch of issues under each epic.
Is there any way I can use JQL to get a list of issues where the epic link of the issues is linked to a specific initiative?
Right now I am typing out the keys for all of the epics but it is always nice when there is a faster way.
And for those of us on cloud, where the above childIssuesOf function does not work...
issuekey in portfolioChildIssuesOf("<issuekey>")
That will return all issues that parent back to the initiative issue key listed. YEAH!
thanks a lot but I have got a couple more questions:
1- I cannot find the reverse function, ie. something called "portfolioParentIssuesOf(""), does it exist? How can we obtain the same effect if it does not?
2- does the portfolioChildIssueOf accept a subquery as argument?
would greatly appreciate any answer.
1 - A given issue can only have a singular parent - thus no function to search.
2 - no idea.
This works, Thanks :)
Hi all, I am trying to use this one to create a filter for All issues under multiple Initiatives, but the OR does not work. Any ideas? Thanks
You should be able to list multiple issuekeys (comma separated) within the parentheses using the same query. Let me test that.Nevermind, that function only expects one argument...
You need to get more parenthetical:
(issuekey in portfolioChildIssuesOf("issuekey")) OR (issuekey in portfolioChildIssuesOf("issuekey"))
You should be able to continue to add
for as many iterations as necessary.... though I imagine there is a limit somewhere...
Hi Abel,
Thanks a lot, that is how I "workarounded" it. Much appreciated, worked now.
Hello @bilyana_karayaneva you can also use this method:
issuekey in (portfolioChildIssuesOf("issuekey1"),portfolioChildIssuesOf("issuekey2"))
This should work the same as the OR and will provide you with all the child issues of the initiatives. I find this works better than the OR as it is more concise.
hi @Kat Warner,
This is possible since portfolio 2.10.
issuekey in childIssuesOf("<Issue key>")
Reference:
Portfolio for Jira 2.10 release notes
Hope this helps!
Yei!!! Glad to hear @Kat Warner 😊
Hi ,
issuekey in childIssuesOf("<Issue key1>" , "<Issue key2>")
Gives me an error "Function 'childIssuesOf' expected '1' arguments but received '2'." because the function wont take more than one argument. So how can i solve this.
You can only have one issue key (the key of the initiative) in this JQL. You could use OR and repeat the JQL for each initiative (I have not tested this myself).
The list of child issues does include the epics as well as the stories and tasks under the epics.
Thank you Alana - saved me so much time and effort!
The function portfolioChildIssuesOf is only available to Jira Premium users, according to the JQL error I get when I try to use it.
Me too. Only available to Premium Users.
Anyone help here?
