JQL filter help
Kerry Penhallurick
December 16, 2024
I have a project where I split time across several clients, I have a custom field for the 'clients to bill' which is a multiple selection list that can select up to 5 clients. I also have a field 'number of clients' that is a text field in which a number is placed so I can split the time properly amounst the applicable clients.
The help I need is to create a query for find instances where the count of the clients in the 'clients to bill' field doesn't match the number in the 'number to bill' field'
December 16, 2024
Hi @Kerry Penhallurick -- Welcome to the Atlassian Community!
That is not possible with the built-in features of JQL.
Your workaround options depend upon how frequently you need to do queries like this and willingness to invest money / time:
  • need this one time
    • export the issues' fields to a spreadsheet and perform the check there
  • need this often
    • willing to invest money
      • Search the Atlassian Marketplace for addons to JQL which may help with such queries
    • willing to invest time
      • Build an automation rule which counts the values selected, set an indicator when the value does not match your "number of clients" field
Kerry Penhallurick
December 20, 2024
Thanks Bill, tha's really helpful
Like Bill Sheboy likes this
