JQL filter: show tasks where subTasks was not created sins 3 weeks
mad_irfan April 2, 2020
hi
is there a way to search for ALL Tasks "issuetype task"  were SubTasks was not created sins 3 weeks.
thx for your support ;)
Jack Nolddor _Sweet Bananas_
Hi mad irfan,
Sadly you cannot achieve the desired search using standard features on Jira, you must go for a third-party app instead. Using i.e. JQL Booster Pack you can type the following:
Search for Tasks were SubTasks was not created sins 3 weeks, i.e.:
issue IN hasSubtaks() AND issue NOT IN parentsOf("type IN subTaskIssueTypes() AND createdDate > -3w")
Note that this is just an example, you must tune above query to fit your needs
Using this app you can also query other issues relations, check:
References:
Hope this helps you to create awesome queries <3
Kind regards
