JQL filter to exclude issues that have ONLY a specific component
Aljoscha Zöller November 11, 2024
The service management project has some components (alpha, bravo, charlie, delta, echo..).
I want to have a queue (based on a JQL filter) where I want to
  • show all issues with no components (component IS EMPTY)
  • show issues that have one or more components
  • do not show issues that are only related to the component "alpha" (component != "alpha")
    • (issues with component "alpha" + at least another component need to be in result set)
The only way I can think of is to list all components except "alpha":
component IS EMPTY or component IN ("bravo", "charlie", "delta", "echo")
Unfortunately if someone adds a component to the project in the future, this JQL filter will have to be updated. This can be a huge source of errors.
Is there a way to do this generic (excluding one value)? In SQL you would for example work with a subquery.
Thank you very much
2 accepted
Florian Bonniec
Hi @Aljoscha Zöller
I'm afraid that in order to display issue with a component and not other, you have to list them all like
component = "A" AND component not in ("B", "C", "D", ...)
I check Scriptrunner JQL function but did not find a way to do it for this field. In theory this should have worked, I use it for other custom field but it do not seems to work for component field.
componenets = A and NOT issueFunction in issueFieldMatch("component is not empty","components","(.*)[,](.*)")
Maybe there is another 3rd party app that provide synch JQL function.
Regards
Hannes Obweger - JXL for Jira
Hi @Aljoscha Zöller
just to add to @Florian Bonniec's great answer:
If you're open to solutions from the Atlassian Marketplace, this would be easy to do using the app that my team and I working on, JXL for Jira.
JXL is a full-fledged spreadsheet/table view for your issues that allows viewing, inline-editing, sorting, and filtering by all your issue fields, much like you’d do in e.g. Excel or Google Sheets.  It also comes with a range of advanced features, including the ability to filter issues via regular expressions
With regular-expression-based filtering, you can apply pretty much any logic, including the one that you are after:
The regex that I'm using is
^Portal fluid$
which matches issues that have this exact one component set.
Once you've identified your issues, you can work on them directly in JXL (e.g., bulk edit them via copy/paste), or trigger various operations in Jira.
I should also add that JXL can do much more than the above: From support for configurable issue hierarchies, to issue grouping by any issue field(s), sum-ups, or conditional formatting.
Best,
Hannes
SERVER
VERSION
5.12.13
