JQL for comparing 2 string fields
Orit Nachshon
I want to compare 2 fields in a simple JQL:
I want to find all issues in a project that the "Summary" field has the same text as "Acceptance Criteria" (custom field).
How can I do it without plugins?
Thomas Schlegel
January 30, 2018
Hi Orit,
simple answer, you can't. There's no way to compare two field values.
Orit Nachshon
:-( Strange...
Thomas Schlegel
January 30, 2018
JQL is not SQL... You can query issues that have the same text as a fixed value but there is nothing like a subquery-concept in JQL. And that is what you need for that kind of comparison.
There are options with plugins, but you asked for a solution without additional apps.
Orit Nachshon
Thanks.
So I found a workaround - to create a hidden and calculated custom field that will indicate (True / False) if the fields are alike, and use it on the JQL.
What do you think? Any other workarounds you can think of?
Sarah Aubuchon April 7, 2020
@Thomas Schlegel
What Plugin could we use to compare 2 field values?
