JQL function powercript
Marat January 29, 2020
I'm trying to find issues with a specific"issuetype" in which a issues with a specific"issuetype" is linked.
what i tried:
project = xx and issuetype = test1 and key in hasAnyLinks(' issuetype = test2')
what i want to get:
all issues withe type test1 in project xx who have "Issue Links" to issue(s) type test2
Jack Nolddor _Sweet Bananas_
Hi Marat,
Sadly you cannot achieve the desired search using standard features on Jira, you must go for a third-party app instead. Using i.e. JQL Booster Pack you can type the following:
Search Bugs under EMEA project with linked Support tickets:
project = EMEA AND type = Bug AND issue IN linkedIssuesOf("type = Support")
Using this app you can also query other issues relations, check:
References:
Hope this helps you to create awesome queries <3
Kind regards
Thanks for the advertisement.
I already have a plugin that extends the capabilities of jql - PowerScript
Can you help me resolve the issue using PowerScript?
Sorry I've never used that app. Could you try the following instead?
project = EMEA AND type = Bug AND key IN issuesLinkedAtDepth("type = Support", 1)
January 30, 2020 edited
Hi Marat,
Had you got the chance to try the suggested JQL using the issuesLinkedAtDepth() function provided by PowerScript?
Did it helped you?
Regards
Register now
