JQL previous status
Adolfo Casari
May 29, 2015
Is there any JQL command (from Atlassian or 3rd party plugin) to query an issue previous status? I need to check all issues whose last transition was from status B (previous) to A (current).
Currenly JQL support:
status CHANGED FROM "B" TO "A"
but I need the last transition only, and the above can return any transition in the issues history.
Thanks in advance,
Udo Brand
May 29, 2015
Another idea would be to use a scripted field which would show the last status (see Hennings answer how to get that) and then search for that one.
"Last Status" ~ "B" and status = "A"
Adolfo Casari
May 30, 2015
Thanks, this is a good approach.
Udo Brand
May 29, 2015
I'm not aware of such a JQL function. The closest you can currently get is
status CHANGED FROM "B" TO "A" and status = A
optionally add
and not status changed from "C" to "A"
Nauman Ikram April 23, 2019 edited
adding above both rows don't return any result. Ideally it should return the result set.
currently using following lines
AND STATUS  CHANGED FROM "B" TO "A"
AND STATUS WAS NOT IN ("C","D","E")
