JQL query for comments for particular user
tjayantha
we want list comments added by particular user in a project/Issue ,is it possible to get by JQL ?
2 accepted
20 votes
Amy Bell
A cool workaround I found for pulling relatively smaller lists of tickets that a user updated (such as commented on):
Add an Activity Stream gadget to a dashboard - and then click Edit in upper right.  Add a Global Filter:
"Username" "is" "(username)"
Viola!
Morgan_Heijdemann April 26, 2016
Worked beautifully for me, thanks!
Mats Nordgren May 2, 2016
I wish I could give you +10!
Network Support
October 14, 2016
This worked amazingly well for some quick clean up I needed to do.
Rivo Tahina Razafindratsifa
December 1, 2017
Thanks ! It works like a charm. Is there any way to export the result ?
Tommy Rowe December 9, 2017
This isnt working, and hasnt for a bit - Anyone heard any news on this being broken?
Liz_Pat
Nice trick. Thanks.
alon
March 10, 2021 edited
Can't make "Username" "is" "(username)" to work....  Tried different ways of filling  username:
  • "Agent Smith"
  • "agent smith"
  • agent smith
  • Agent Smith
  • 5f59dc7ef0d30600f657dcff    (This is the user's Jira ID)
  • All of the above with ( ) in \ out of the " "
Any ideas?
NOTE:
Jira won't auto complete the username as it does in the JQL filter
Like 2 people like this
Oleksandr Kulychok
March 25, 2021
Goto your profile and copy value from Username
9 votes
JamieA
February 4, 2013
You can try script runner and use the jql issueFunction in commented ("by username")
Can't point you to the docs at the moment because the site is being moved.
Renjith Pillai
February 4, 2013
Hey Jamie. Saw that movement. Need a hand to get some editing/formatting of the pages? (saw some invalid macros)
May be you can set the default confluence theme for documentation as well.
Кирилл Домасевич
August 14, 2019
JamieA, thx a lot. Exactly what I'm looking for, not like a workaround approaches above ;-)
3 votes
John Gooch
Even better,  this JQL works for me. you can reduce it to only the parameters that interest you.
(summary ~ currentUser() OR description ~ currentUser() OR comment ~ currentUser()) and updatedDate >= -7d
Lesa King February 16, 2018
I am unable to return the ticket Comments field with this or any other query. Like the original request, that is what I need: a list of comments.  Is there something I am not seeing that allows me to select that field in the results?
David Leal
September 20, 2023
 @John Gooch yes, it works for the current user, but I don't think it works for other that the current user executing the JQL.
3 votes
Clément Grimal
January 20, 2014
I installed the following free add-on: "Script Runner"
Then, you can use the following query
issueFunction in commented("by username")
as described in the documentation: https://jamieechlin.atlassian.net/wiki/display/GRV/Scripted+JQL+Functions#ScriptedJQLFunctions-commented(commentquery)
David Skreiner
June 23, 2016
ScriptRunner is no longer free sad
Like 3 people like this
Naren
February 4, 2013
You can use the JQL Tricks plugin . Use the issue function commentedByUser([User]) to find the list of comment added by particular user
tjayantha
JQL Tricks plugin is paid, do we have any altrenatives ?
David Skreiner
June 23, 2016
As a workaround, you can use a dashboard:
1 open Dashboard
2 Add Gadget Activitiy Stream
3 Add a global filter: Project is XY
4 Add a global filter: User is (username)
5 Below the Global Filter, klick JIRA - Add Filter:  Activity is Comment
6 Set "limit to 99 items"
You now have the comments as an activity stream.
Help its broken - please fix Atlassian
luisxicano
March 20, 2019
Hola, existe alguna forma de auto asignar una incidencia a un usuario determinado de forma automatica? He realizado un filtro donde me muestra solo las subtareas hijas que ya estan en estado franqueadas, pero necesito que se asignen a un usuario en concreto de forma automática conforme esas subtareas vayan apareciendo. Es posible?
basicamente lo necesito para no tener que estar entrando en el filtro y tener que asignarlas yo manualmente a un usuario para que las gestione.
Rahul Ingle April 2, 2019
comment~rahul.ingle AND project = test
Jason Kovacs
This might help someone find all issues with comments across multiple users, though you have to go to each detail to see them.
Use this JQL advanced filter for the All Issues list:  comment !~ "junktext"
This returned all the issues that have comments because they do not contain "junktext".
Mert Karadağlı _ Köstebek Teknoloji _
You can use JIRA Comment Toolbox plugin.
You can find the list of the issues which is commented by current user , selected user, group member and role member and you can limit this search with comment date or last comment.
If you need any custom JQL for comments you can also contact with us, mailto:info@kostebekteknoloji.com.
