Sign up Log in
JQL: query issues where assignee != project lead; or where assignee != reporter
Derek MacNeil
June 22, 2012
I'm looking to create a filter where issues are not assigned to the project lead. Another way this could work is if the current assignee is not the same as the reporter:
- project = 'my project' and assignee != reporter
- project = 'my project' and assignee != projectlead()
Something along those lines. Any suggestions?
Filipe February 25, 2014
You can give a try on:
https://marketplace.atlassian.com/plugins/pt.lt.lfcribeiro.jira.jqlLTFunctions
It lets you run SQL staments in a JQL functions(executeQuery() )
Thx
Nancy Blackwell
December 29, 2013
Scripted field doesn't work because the scripted field is not rendered until the browser displays the issue (I think). Our solution was to have a number field set to -1 on create, then when we assign the issue back to the requester, we set it to 0. Then the number field is searchable. Note: This only works if you know when you are setting it back to the requester through post functions.
JamieA
April 16, 2014
Scripted field will work fine providing you set an indexer. Better to use a jql function though.
Norman Abramovitz
June 23, 2012
I do not know how many project leads you have per project but if your environment is simple(ie small number of project leads) then you could create groups for each project containing the project leads and then use the membersOf function like:
assignee not in membersOf("projectx-project-leads")
Norman Abramovitz
June 23, 2012
Again, if the number of project leads is small, you could just list them like
assignee not in ( name1, name2 )
Dieter
June 22, 2012
Such queries that do not work out of the box can be implemented using a scripted custom field which returns 1 if a certain condition holds. More information about how to create scripted custom fields can be found here: https://studio.plugins.atlassian.com/wiki/display/GRV/Scripted+Fields
For the first query you should create a scripted field, e.g. scriptedfield1 which returns "1" if the assignee equals the reporter else it returns "0"
Then you could use
project = 'my project' and scriptedfield1 != "1"
Similar can be done for project lead
