Helo,
I know I saw a fix for this a while ago but, I cannot find it. I was looking into doing certain queries in my project like this:
project = "myproject" and component = "this" OR component = "that" OR component = " there" AND resolution = Unresolved AND created > -1w AND status = open
but, I'm getting tickets that are either resolved and closed in the results.
You need to use brackets if you use "OR"
project = "myproject" and (component = "this" OR component = "that" OR component = " there") AND resolution = Unresolved AND created > -1w AND status = open
thank you that fixed it :)
Try wrapping everything with an or in parentheses. Example:
Also the resolution field are set as fixed for the closed ones.
Save your spot
