No.
JQL is for finding issues. Not reporting the data in them.
You'll need to find or write something that can "pull" the relevant data and display it.
It's not possible, like Nic wrote. But maybe this helps:
https://answers.atlassian.com/questions/143221/transition-report-on-all-issues
Henning
Hi Henning, i have realised that as well that JQL cant pull report no matter how you manipulate and thanks for your advice on the link but it doesnt open:
Mmmh, for me it works. If it doesn't work, try to search for "Transition report on all issues".
Henning
