JQL search for single component only
Anton Fomin April 20, 2016
Let's say I have many components: A, B, C, X... and so on.
Let's say I have issues with these components assigned:
  • Issue A
  • Issue A + B
  • Issue A + C
  • Issue A + X
  • .. and so on
How can I write query that selects "Issue A" only, if I may not know how many combinations A can have?
Anton Fomin April 21, 2016
Thanks Peter, but what if I have many components other's than A? Hardcoding all of them in the query and updating them each time new combination gets added is not worth it.
Peter T
April 21, 2016
You have to hardcode something, otherwise it can't function.
If I understand correctly you want to do Component = A and Component != different Than A
This can be accomplished with either custom JQL or custom scripted field that shows you the number of components and in this case the JQL will be
Component = A and ComponentCount = 1.
Peter T
Anton Fomin April 27, 2016
Thanks Peter!
Varora1406
May 10, 2019
How to add this ComponentCount?
Like • Nicolas Lagier likes this
Peter T
April 20, 2016
Hi Anton,
yes you can:
component = A and component != B
