JQL to JSON format
Sergey Shestakov
August 2, 2017
Please, show me example of converted JQL query to JSON:
jql query: issuekey in (test1,test2)
Nic Brough -Adaptavist-
August 2, 2017
The docs have a couple of examples well buried.  But it is as simple as embedding the string:
{"jql":"issuekey in (test1,test2)"}
Sergey Shestakov
August 2, 2017
Thanks, work!
Warren
August 2, 2017
Hi Sergey
I'm not aware that you can convert from one to the other. JSON is used to return data from an API request; the request may or may not have contained some JQL.
Could you explain in some more detail what you're trying to do / achieve?
Warren
