I want to show all stories in my project which are coming from epics in all projects other than mine.
How can i achieve that?
Shirley
Hello Shirley,
I understand that you would like to return all issues that are under an Epic from a different project than yours. Is that correct?
You can use the Script JQL Functions from ScriptRunner plugin to configure the following query:
project = yourproject and "epic link" is not empty and issueFunction in issuesInEpics("project != yourproject)
To know more about this query, refer to the Epics session of the documentation below:
Let me know if it works for you, Shirley.
If the stories are in your project, then JQL project = yourprojectname AND issuetype = story.
If the stories dwell on other boards (projects) and not yours, then it gets more complicated.
Can you give an example?
Ryan
This is similar to what I am trying to do. Here's the use case
I have Epics in Project A. Those Epics have stories linked to them in Project B, Project C, etc.
I'd like to create board in Project A where I can see all stories in Project B, Project C, etc. that are ONLY linked to Epics in Project A.
