Hello! I've followed this instructions to enable SSL (through my CloudFlare domain) on my Jira DC instance:
https://thejiraguy.com/2021/10/14/adding-ssl-to-jira/
Unfortunately it didn't work. I get a constant 301 loop (I guess http sends to https and so on?).
I'm going a bit crazy trying to figure out where the loop happens. I've tried a few options like setting ProxyRequests Off
and also setting my domain directly as HTTPS:
ProxyPass / https://jira.mediasoft.com:8080/
ProxyPassReverse / https://jira.mediasoft.com:8080/
But that didn't work either.
All my our other tools (Zabbix, Grafana, WikiJS) work just fine on reverse proxy Apache, not sure what's the deal with Jira not wanting to kick into work. Maybe an issue with Cloudflare?
Should Tomcat be listening on 443 instead of Apache??
ss -tulpn
Netid State Recv-Q Send-Q Local Address:Port Peer Address:Port Process
udp UNCONN 3584 0 0.0.0.0%eth0:68 0.0.0.0:* users:(("wickedd-dhcp4",pid=892,fd=8))
udp UNCONN 0 0 127.0.0.1:323 0.0.0.0:* users:(("chronyd",pid=1448,fd=5))
udp UNCONN 0 0 [::1]:323 [::]:* users:(("chronyd",pid=1448,fd=6))
tcp LISTEN 0 128 0.0.0.0:22 0.0.0.0:* users:(("sshd",pid=13260,fd=3))
tcp LISTEN 0 10 *:8090 *:* users:(("java",pid=27041,fd=45))
tcp LISTEN 0 100 *:8080 *:* users:(("java",pid=4508,fd=121))
tcp LISTEN 0 128 [::]:22 [::]:* users:(("sshd",pid=13260,fd=4))
tcp LISTEN 0 4096 *:80 *:* users:(("httpd-prefork",pid=5470,fd=4),("httpd-prefork",pid=5469,fd=4),("httpd-prefork",pid=5468,fd=4),("httpd-prefork",pid=5467,fd=4),("httpd-prefork",pid=5466,fd=4),("httpd-prefork",pid=5452,fd=4))
tcp LISTEN 0 4096 *:443 *:* users:(("httpd-prefork",pid=5470,fd=6),("httpd-prefork",pid=5469,fd=6),("httpd-prefork",pid=5468,fd=6),("httpd-prefork",pid=5467,fd=6),("httpd-prefork",pid=5466,fd=6),("httpd-prefork",pid=5452,fd=6))
tcp LISTEN 0 1 [::ffff:127.0.0.1]:8000 *:* users:(("java",pid=27041,fd=79))
tcp LISTEN 0 1 [::ffff:127.0.0.1]:8005 *:* users:(("java",pid=4508,fd=506))
My `server.xml` connector settings:
<Connector port="8080" relaxedPathChars="[]|" relaxedQueryChars="[]|{}^\`"<>"
maxThreads="150" minSpareThreads="25" connectionTimeout="20000" enableLookups="false"
maxHttpHeaderSize="8192" protocol="HTTP/1.1" useBodyEncodingForURI="true" redirectPort="8443"
acceptCount="100" disableUploadTimeout="true" bindOnInit="false" secure="true" scheme="https"
proxyName="jira.mediasoft.com" proxyPort="443"/>
Help us plant more trees
