Here the problem I'm running into. I'd like to do a transition in the following scenarios:
Component starts with A, Component starts with B, or Component is null
I'm running into a problem with the null statement because maybe the Component isn't initialized? When doing a boolean expression, I've tried the following:
substring(%{00094}, 0, 1) != "A" or substring(%{00094}, 0, 1) != "B" or %{00094} = null
Is there something obvious I'm missing?
Hi @wesley.segafredo ,
evaluating the substring() function will lead to an error when the components are actually empty. Given your scenario, the following expression should work:
%{00094} = null ? true : substring(%{00094}, 0, 1) = "A" or substring(%{00094}, 0, 1) = "B"
This would result in:
Please be aware of the fact that this expression fits best for single components.
In general, you can try and build your expressions using the expression parser test page - see https://apps.decadis.net/display/JWT/Expression+Parser+Test.
Cheers
Thorsten
