Hi Guys,
I'm traying to configure Java Melody dabatase monitoring without sucesss. I followed the instructions of Java melody wiki https://github.com/javamelody/javamelody/wiki/AtlassianPlugin.
Also I found this question https://community.atlassian.com/t5/Jira-questions/How-to-configure-Java-Melody-in-JIRA-5-or-6-so-it-does-monitor/qaq-p/7319 without success again.
Can someone help me?
This is a Jira 7.1 and MySQL, its a test envinronment.
server.xml
<Engine name="Catalina" defaultHost="localhost">
<Host name="localhost" appBase="webapps" unpackWARs="true" autoDeploy="true">
<Context path="" docBase="${catalina.home}/atlassian-jira" reloadable="false">
<Resource name="jdbc/jiradb" auth="Container" type="javax.transaction.UserTransaction"
username="xxxx"
password="xxxx"
driverClassName="com.mysql.jdbc.Driver"
url="jdbc:mysql://localhost/jiradb"
maxActive="20"
maxIdle="10"
<Resource name="UserTransaction" auth="Container" type="javax.transaction.UserTransaction"
factory="org.objectweb.jotm.UserTransactionFactory" jotm.timeout="60"/>
<Manager pathname=""/>
<JarScanner scanManifest="false"/>
</Context>
</Host>
dbconfig.xml
<?xml version="1.0" encoding="UTF-8"?>
<jira-database-config>
<name>defaultDS</name>
<delegator-name>default</delegator-name>
<database-type>mysql</database-type>
<jdbc-datasource>
<url>jdbc:mysql://localhost:3306/jiradb?useUnicode=true&characterEncoding=UTF8&sessionVariables=default_storage_engine=InnoDB</url>
<driver-class>com.mysql.jdbc.Driver</driver-class>
<username>xxxx</username>
<password>xxxx</password>
<pool-min-size>20</pool-min-size>
<pool-max-size>20</pool-max-size>
<pool-max-wait>30000</pool-max-wait>
<validation-query>select 1</validation-query>
<min-evictable-idle-time-millis>60000</min-evictable-idle-time-millis>
<time-between-eviction-runs-millis>300000</time-between-eviction-runs-millis>
<pool-max-idle>20</pool-max-idle>
<pool-remove-abandoned>true</pool-remove-abandoned>
<pool-remove-abandoned-timeout>300</pool-remove-abandoned-timeout>
<pool-test-on-borrow>false</pool-test-on-borrow>
<pool-test-while-idle>true</pool-test-while-idle>
<validation-query-timeout>3</validation-query-timeout>
<schema-name>public</schema-name>
<jndi-datasource>
<jndi-datasource><jndi-name>java:comp/env/jdbc/jiradb</jndi-name></jndi-datasource>
</jndi-datasource>
</jdbc-datasource>
</jira-database-config>
Hi everyone,
For configure your Java Melody database monitoring in a SQL Server, take a look on this example.
Dbconfig.xml
<database-type>mssql</database-type>
<schema-name>Jira_Schema</schema-name>
<url>jdbc:sqlserver://localhost:1433;databaseName=jiradb</url>
<driver-class>com.microsoft.sqlserver.jdbc.SQLServerDriver</driver-class>
<username>xxxxx</username>
<password>xxxxxx</password>
<jndi-datasource><jndi-name>java:comp/env/jdbc/JiraDS</jndi-name></jndi-datasource>
server.xml
<Context path="" docBase="${catalina.home}/atlassian-jira" reloadable="false" useHttpOnly="true">
<Resource name="jdbc/JiraDS" auth="Container" type="javax.sql.DataSource"
username="xxxxxx"
password="xxxxxx"
driverClassName="com.microsoft.sqlserver.jdbc.SQLServerDriver"
url="jdbc:sqlserver://localhost:1433;databaseName=jiradb"
maxActive="20"
maxIdle="10"
validationQuery="select 1"
Hello @Fabio Manzoni
So you need to keep both <jdbc-datasource> and <jndi-datasource> in the dbconfig.xml + add the resource in server.xml ?
https://github.com/javamelody/javamelody/wiki/AtlassianPlugin says to replace it : "To configure JIRA with a datasource, replace in the jira-home/dbconfig.xml file "<jdbc-datasource>...</jdbc-datasource>" with "<jndi-datasource>"
Thanks.
Sylvain
Fabio,
Can you tell us exactly what is not working and error messages that you see?
Shannon
Hi Shannon,
Thank you for your attention. It's a test environment and I solved the problem in MySQL database with this information below. But now I try to use the same configuration to Microsoft SQL, but doesn't work. This configurarion enable the data base monitoring on Java Melody. And I will apply this in our costumer.
This Work in MY SQL
Server.xml
username="xxxxxx"
password="xxxxxx"
url="jdbc:mysql://localhost:3306/jiradb"
maxActive="20"
maxIdle="10"
</Context>
dbconfig.xml
This Doesn't work on Microsoft SQL
Server.xml
username="xxxxx"
password="xxxxx"
url="jdbc:mssql://localhost:1433/jiradb"
maxActive="20"
maxIdle="10"
</Context>
dbconfig.xml
<username>xxxxxx</username>
Best Regards,
Fabio
This is the message error.
If I remove the java melody information, this instance works very well.
Microsoft SQL - Doesn't Work
My SQL - Working.
It Works...
I did a mistake and put the mssql-jdbc-6.4.0.jre8 file on Jira. It's wrong!
The dbconfig.xml is correctly and the server.xml I did some adjust, see below.
I hope this information can now help other people...
server.xml
username="xxxxxx"
password="xxxxxx"
maxActive="20"
maxIdle="10"
Hi Fabio!
Thank you for confirming you were able to resolve your issue.
If you'd like, you can put your fix in as a separate Answer (below Suggest an answer) and I can mark it as the accepted answer.
Shannon
Thank you for your suggestion Shannon. I put in Suggest an answer.
I have the same problem.
But not for mysql but for postgress
server.xml
<Context path=""
reloadable="false"
useHttpOnly="true">
username="xxxx"
password="xxxx"
driverClassName="org.postgresql.Driver"
url="jdbc:postgresql://xxxxxx"
db.config.xml
<database-type>postgres72</database-type>
<jdbc-datasource>
<url>jdbc:postgresql://xxxxxxxxxx</url>
<driver-class>org.postgresql.Driver</driver-class>
<password>xxxxx</password>
</jdbc-datasource>
<jndi-datasource>
<jndi-name>java:comp/env/jdbc/jirads</jndi-name>
</jndi-datasource>
Any suggestions?
Get Certified! ✍️Online forums and learning are now in one easy-to-use experience.
