×I am trying to analyze the processes in a project and want to get all the issues in it with Java.
Since the maximum amount of issues that is possible to get retrieved with a JQL is 1000 I am trying to write a loop to get them all.
Is there a way to get the number of issues in a project as an integer value? In the JIRA GUI, I can see this value, so it must be somewhere saved. If so I can use the Java REST API to retrieve it.
If not I will do it with a while-loop.
Found the answer I was looking for.
In the
final SearchResult searchResult = restClient.getSearchClient().searchJql(...);
searchResult variable there is a property named total, so with a
searchResult.getTotal()
I got the value I was looking for and will use it in a Do-While Loop.
Hi!
Yes, in the response you can see parameters, like limit, start and isLast, and total of number issues.
You can play it by python.
e.g.
https://github.com/atlassian-api/atlassian-python-api/blob/master/examples/jira-jql-query.py
Also, you can from your browser the result of pagination
hope it helps
Gonchik Tsymzhitov
Jap, thanks for the answer.
I found a similar solution in Java though.
