Java script is not working
Chaithra N
August 6, 2014
We are testing JIRA 6.2.7.
If Java scripts is placed in the CustomField of Type User (in field config scheme), script does not work.
But if same script is placed in any other Field Type, script will work.
Can any one help on this.
Sample Script:
<script type="text/javascript">
var summaryfld = document.getElementById('summary').parentNode;
document.getElementById('summary').value= 'Test Summary';
summaryfld.style.display = 'none';
</script>
Even normal html code doesnot work if placed in user field
<b> Testing description </b>
RambanamP
August 6, 2014
you need to include your script in
&lt;script type="text/javascript"&gt;
   jQuery(document).ready(function($) {
       JIRA.bind(JIRA.Events.NEW_CONTENT_ADDED, function (e,context) {
			$("#summary").val("Test Summary");
			$("#summary").closest('div.field-group');
&lt;/script&gt;
check the following question
https://answers.atlassian.com/questions/47843/strange-javascript-problem-in-create-screen
Chaithra N
August 6, 2014
Thanks for commenting.
Still no luck, java script doesnot run if used on the User field.
RambanamP
August 6, 2014
add the above script on annoucement banner and check first
Chaithra N
August 6, 2014
Script works fine in Announcement or any other fields.
Failing only on User Field
RambanamP
August 7, 2014
as i specified in my answer on given link you need to add javascript in a plugin as webresource module
