JavaMelody download
Mengmeng Yu
is there any other way to download the JavaMelody plugin
I download jira-confluence-javamelody-1.87.0.jar from below link.
https://github.com/javamelody/jira-confluence-javamelody/releases
but the website is blocked for me because of HSBC policy.
is there any other way I can download this jar file?
2 accepted
Daniel Eads
June 2, 2021
There is a much, much older version available on the original project hosting on Google Code. That might be worth a shot to get around your company's domain block, but again - this is a very old version.
It's possible you could download a current release from Github (the official source) from a personal machine and transfer it via a flash drive or email to your work machine. This would be necessary if you're trying to install it on an air-gapped machine, for example. I think this might be close to the case given that you're getting an NXDOMAIN trying to ping it.
I would also recommend just reaching out to your IT team and explaining the situation - you need some software from the internet to do your job properly, and their current policy is preventing you from getting it. Either they'll have a workaround (for example, using a flash drive) or they'll need to revisit the particular policy.
Mengmeng Yu
Hi Daniel,
Thanks for your advice, this old version might not be compatible with my Jira-8.8.1.
will try to download from my personal machine.
Pavel Junek
If you have Jira installed on Linux, you can download it from the command line (depending on the type of Linux):
curl -L0 https://github.com/javamelody/jira-confluence-javamelody/releases/download/1.87.0/jira-confluence-javamelody-1.87.0.jar
or
wget https://github.com/javamelody/jira-confluence-javamelody/releases/download/1.87.0/jira-confluence-javamelody-1.87.0.jar
For Windows Server you can use PowerShell:
$client = new-object System.Net.WebClient
$client.DownloadFile("https://github.com/javamelody/jira-confluence-javamelody/releases/download/1.87.0/jira-confluence-javamelody-1.87.0.jar","C:java_melody.jar")
 Pavel
Mengmeng Yu
Hi Pavel.
thx for reply.
I don't know why my brower can access  github.com. but my linux server can't notify this hostname. and I can't also ping github.com in powershell.
Mengmeng Yu
Any other way I can get the jar file. I was trying to download the source code. but I encounter some license error when I extract it.
