<script> checkbox_11106_1 = document.getElementById('customfield_11106-1'); //New - Yes checkbox_11106_2 = document.getElementById('customfield_11106-2'); //New - No if (!checkbox_11106_1.checked){ AJS.$("#customfield_11118").closest('div.field-group').show(); } if (!checkbox_11106_2.checked){ AJS.$("#customfield_11118").closest('div.field-group').hide(); document.getElementById('customfield_11118').value = ''; } checkbox_11106_1.onclick=function(){ if (checkbox_11106_1.checked){ AJS.$("#customfield_11118").closest('div.field-group').hide(); document.getElementById('customfield_11118').value = ''; } }; checkbox_11106_2.onclick=function(){ if (checkbox_11106_2.checked){ AJS.$("#customfield_11118").closest('div.field-group').show(); } }; </script>
How can I resolve this problem?
Now it works. I'm using this script at the custom field
<script> function newField(){ if (document.getElementById('customfield_11106-1').checked){ AJS.$("#customfield_11118").closest('div.field-group').hide(); document.getElementById('customfield_11118').value = ""; } if (document.getElementById('customfield_11106-2').checked){ AJS.$("#customfield_11118").closest('div.field-group').show(); } AJS.$('#customfield_11106-1').click(function(){ if (document.getElementById('customfield_11106-1').checked){ AJS.$("#customfield_11118").closest('div.field-group').hide(); document.getElementById('customfield_11118').value = ""; } }); AJS.$('#customfield_11106-2').click(function(){ if (document.getElementById('customfield_11106-2').checked){ AJS.$("#customfield_11118").closest('div.field-group').show(); } }); } AJS.$(document).ready(function(){newField()}); AJS.$(document).bind('dialogContentReady', function(event, dialog){newField()}); JIRA.bind(JIRA.Events.NEW_CONTENT_ADDED, function(e,context){newField()}); newField(); </script>
And using this script at the announcement banner
<script type="text/javascript"> AJS.$("#create_link").removeClass("create-issue"); </script>
Hi Ana,
I am able to use your example script, but my JIRA hangs up when I create a project/issue type that does not have the two custom fields in the create screen. Can you help? Thanks
This is the script:
<script>
if (document.getElementById('customfield_10201').value != 35){
AJS.$("#customfield_11201").closest('div.field-group').hide();
document.getElementById('customfield_11201').value = "";
if (document.getElementById('customfield_10201').value == 35){
AJS.$("#customfield_11201").closest('div.field-group').show();
AJS.$('#customfield_10201').click(function(){
newField();
</script>
there is a lot of answer to questions like yours. among it this, you must just replace ids of your custom fields.
https://answers.atlassian.com/questions/264320/pop-up-a-user-picker-window
Hi Ana,
Maybe this modification fixes your problem:
<script> (function($) { checkbox_11106_1 = document.getElementById('customfield_11106-1'); //New - Yes checkbox_11106_2 = document.getElementById('customfield_11106-2'); //New - No if (!checkbox_11106_1.checked){ AJS.$("#customfield_11118").closest('div.field-group').show(); } if (!checkbox_11106_2.checked){ AJS.$("#customfield_11118").closest('div.field-group').hide(); document.getElementById('customfield_11118').value = ''; } checkbox_11106_1.onclick=function(){ if (checkbox_11106_1.checked){ AJS.$("#customfield_11118").closest('div.field-group').hide(); document.getElementById('customfield_11118').value = ''; } }; checkbox_11106_2.onclick=function(){ if (checkbox_11106_2.checked){ AJS.$("#customfield_11118").closest('div.field-group').show(); } }; })(AJS.$); </script>
For properly working javascript, you have to provide it as a web ressource plugin. See https://answers.atlassian.com/questions/287928/adding-javascript-to-hide-and-prefil-summary-while-creating-an-issue
Henning
Help us plant more trees
