JavaScript to show a field depending on context and make it mandatory.
Ryan Aherne
October 14, 2012
I'm looking for some JavaScript to make a field mandatory, similer to other mandarory fields in JIRA.
I have a field that needs to be mandatory, but this field's content (and data) will change depending on the context. I'm actually talking about three custom fields of different type with the same name. Depending on the context selected, depends on which custom field is displayed.
Context: X, Y, Z
X-> display db values custom field (pointing to db1)
Y-> display dropdown custom field
Z-> display db values custom field (pointing to db2)
Field displayed/name as 'Project' and needs to be mandatory, no matter what the context. So I'm looking for JavaScript to show the field depending on context (use selected) and made it mandatory.
Any suggestions or help appreciated.
Ryan Aherne
October 15, 2012
I decided to change my approach. I moved up one level to the issue type, creating a different issue type for each context. Each issue type has it's own entry form, field config, schemas, etc
No Javascript required ;o)
Ryan Aherne
October 15, 2012
I've marked this as the answer, as it's the solution to my problem. I didn't really answer the question asked ;o)
Nic Brough -Adaptavist-
October 14, 2012
I'm a bit out of my depth with javascript, so I can't help you there, but I did want to point out that Jira's built-in mandatory fields don't work like that. Their content is checked on the server side after the user commits a change.
Register here ⬇️
