Javascript AJS append call
Scheibli Márk August 2, 2017
Hi!
I want to put a label to the operations-delete section but with AJS append call. My code is the following at the moment, but the label not appearing under the delete button:
AJS.$('#operations-delete').append('<li class="aui-list-item"><a href="#" id="my_web_item_link" tabindex="-1"><span class="trigger-label">Push me</span></a></li>');
Can you help me with this? I dont know what the concrete attributes are to write before the append section.
Thor
August 12, 2017 edited
You don't have to use the AJS...
Just do it like:
$('#operations-delete').append("<div>Something</div>");
BTW:
You can use your Web Developer tools in Chrome / Firefox to debug javascript. Open it and propably you'll see an error in a case like this.
Often you just use the wrong scope / timing in JS and something is "undefined" at the time it should be executed.
Scheibli Márk August 15, 2017
Thank your very much! It was'nt that easy but with your function calling i could solve my problem. Here is my latest version of the code:
$('#opsbar-operations_more_drop').append('<div class="aui-dropdown2-section"><ul><li class="aui-list-item"><a href="#" id="listDialog"><span class="trigger-label">PD rendering</span></a></li></ul></div>');
Thor
August 15, 2017
Your welcome & thanks for sharing your latest version :-)
atlassian, loom, AI, meeting recording, community
[NEW] Record your meetings with Loom
Welcome to great meetings, with less work. Automatically record, summarize, and share instant recaps of your meetings with Loom AI.
Learn more
