Javascript code not working in custom field
Mohin Uddin
Hi Expert,
I am using JIRA version 6.2.2 currently I am using some java script code to one custom field.At before It worked fine but now it does not working.
Could you please check this issue and let us know the solution.
codes are given below:
<script type="text/javascript">
if (typeof(CustomTextFiller) == "undefined") {
var CustomTextFiller = new Class({
Implements: Options,
options: {
textareaId: "",
values:[]
initialize: function (options) {
this.setOptions(options);
this.textarea = document.id(this.options.textareaId);
if (!this.textarea && console)
console.log("CustomTextFiller[" + this.options.textareaId + "]: Textarea not found!");
if (this.options.values.length == 0 && console)
console.log("CustomTextFiller[" + this.options.textareaId + "]: No values specified!");
var isNewRecord = true;
var formTitles = $$("h3.formtitle");
for (var i = 0; i < formTitles.length; i++) {
if (formTitles[i].get("text").trim() == "Edit Issue") {
isNewRecord = false;
break;
if (!isNewRecord)
console.log("CustomTextFiller[" + this.options.textareaId + "]: Not a redo request!");
if (this.textarea && this.options.values.length > 0 && isNewRecord) {
this.cycle = this.getCycle();
this.appendLine("[BEGIN_CYCLE_" + this.cycle + "]");
for (var i = 0; i < this.options.values.length; i++) {
var item = this.options.values[i];
var x = item.split(/:0:/g);
var key = x[0];
var value = x.length > 1 ? x[1] : "Undefined";
var div = this.createCheckboxDiv(key, value);
div.inject(this.textarea, "before");
var otherDiv = this.createOtherCheckboxTextboxDiv();
otherDiv.inject(this.textarea, "before");
if (console)
console.log("CustomTextFiller[" + this.options.textareaId + "]: Loaded successfully.");
} else {
if (console)
console.log("CustomTextFiller[" + this.options.textareaId + "]: Not loaded.");
getCycle: function(){
var cycle = -1;
if (this.textarea) {
var regex =  /\[BEGIN_CYCLE_(\d*)\]/g;
var match = null;
while((match = regex.exec(this.textarea.value)) != null)
var x = parseInt(match[1], 10);
if (typeof(x) == "number" && x > cycle) {
cycle = x;
if (console)
console.log("CustomTextFiller[" + this.options.textareaId + "]: Update cycle to " + x + ".");
return cycle + 1;
createCheckboxDiv: function(key, value) {
var checkbox = new Element("input", {
type: "checkbox",
id: this.options.textareaId + "_" + key,
value: value
checkbox.set("key", key);
checkbox.set("value", value);
checkbox.addEvent("click", function(){
var line = checkbox.get("key") + ":" + this.cycle + ":" + checkbox.get("value");
if (checkbox.checked)
this.appendLine(line);
else
this.removeLine(line);
this.textarea.focus();
this.checkbox.focus();
}.bind(this));
var label = new Element("label", {
"for" : this.options.textareaId + "_" + key,
html : value
var div = new Element("div");
div.grab(checkbox);
div.appendText(" ");
div.grab(label);
return div;
createOtherCheckboxTextboxDiv: function() {
type: "checkbox",
id: this.options.textareaId + "_OTHER",
value: "OTHER"
var textbox = new Element("input", {
type: "text",
id: this.options.textareaId + "_OTHER_value"
checkbox.addEvent("click", function(e){
if (textbox.value.trim().length == 0) {
alert("Please enter problem description first!");
e.stop();
} else {
var line = "OTHER:" + this.cycle + ":" + textbox.get("value");
if (checkbox.checked) {
textbox.setProperty("readonly", "readonly")
} else {
textbox.setProperty("readonly", "")
}.bind(this));
"for" : this.options.textareaId + "_OTHER",
html : "Others"
div.grab(checkbox);
div.grab(label);
div.grab(textbox);
return div;
appendLine: function(line){
var lb = window.ie ? "\r\n" : "\n";
if (this.textarea.value.trim().length > 0)
this.textarea.value = this.textarea.value.trim() + lb + line;
else
this.textarea.value = line;
if (console)
console.log("CustomTextFiller[" + this.options.textareaId + "]: Append \"" + line + "\".");
removeLine: function(line){
if (this.textarea && this.textarea.value.trim().length > 0) {
var regexText = window.ie ? "\r\n" + line : "\n" + line;
var regex = new RegExp(regexText.escapeRegExp(), "g");
this.textarea.value = this.textarea.value.trim().replace(regex, "");
if (console)
console.log("CustomTextFiller[" + this.options.textareaId + "]: Remove \"" + line + "\".");
window.addEvent("domready", function() {
var customfield_11695 = new CustomTextFiller({
textareaId: "customfield_11695",
values:[
"New/Changed Functionality:0:New/Changed Functionality",
"Creative Asset Delay:0:Creative Asset Delay",
"GMIT:0:GMIT",
"Bug Fixing:0:Bug Fixing",
"Production Capacity:0:Production Capacity",
"Brand/Legal delay:0:Brand/Legal delay"
</script><font color="red">Please specify the change requirements/details (at every revision round) in the comments box below.</font>
Boris Georgiev [Appfire]
April 16, 2014
That's pretty big piece of code don't you think :). Can you give a hint which part does not work and explain shortly what is it supposed to do ?
Help us plant more trees
