Javascript code sample for authentication with REST API
Prasad August 15, 2019
Could you please help me for some javascript code sample for authentication with REST API?
I am using JIRA - v7.1.10
Andrew
August 15, 2019
Hi @Prasad ,
I use groovy:
class HttpProvider(){
private static String authString
private static credentional(){
Console cons
cons = System.console()
username = cons.read("[%s]", 'Username:')
password = cons.readPassword("[%s]", 'Password:')
this.authString = "${username}:${password}".getBytes().encodeBase64().toString()
private static get(String url) {
def connection = url.toURL().openConnection()
if (this.authString == null) this.credentional()
connection.addRequestProperty("Authorization", "Basic ${this.authString}")
connection.setRequestMethod("GET")
connection.doOutput = false
connection.connect()
connection.content.text
In groovy by default return last operator in method. In java it equals: return connection.content.text
B.R.
Warren
August 15, 2019 edited
Hi @Prasad
Just to add a bit to @Andrew answer, the username needs to be the Jira e-mail address and the password needs to be the API token, as per this post
Prasad August 16, 2019
Hi @Andrew and @Warren .
Thank you for answer. I want to know whether we cannot use plane JavaScript for authentication?
Get Certified! ✍️
