Hi All,
I am using the Behaviours plugin to add behavior to a field.i want to add a Javascript snippet in my Groovy script .
Below is the js which i want to add in my Groovy script
<script type="text/javascript"> AJS.$("#versions option").each(function() { if( AJS.$(this).val() == 'optionId'){ AJS.$(this).remove(); } }); </script>
The optionId in the above code will be provided by the groovy script.
Is this possible ? if yes, how ? (examples with code will be appreciated )
Thank you .
In general it's not a good idea to have code write other code... it gets impossibly difficult to debug and deal with escaping issues.
But, I have not tried it, but if you write javascript using the setHelpText() method it will probably work.
What is it that you're tried to do, it looks like remove a version option that has the literal value optionId?
Hi Jamie ,
I am actually trying to set the options of a version picker . There is a parent child relationship between versions , this relationsihp is stored in an active object table , There are two customfields consider Parent ( A multi version picker) and child (a single version picker). I want to show only the parent versions in the Parent field and only child versions in the child field .
However due to this bug i am not able to set values to the Parent field.
So as a workaround i want to remove options from the Parent field which are child .
:( i have to complete this task this week
Did not get what setHelpText() does and how to include js using this method
Was able to run the script using setHelpText() :) thanx .
How did you add script?
It doesnt allow <script> tags? in fact it doesnt allow any < or /> or </ charachters..
It worked for me ... try escaing it \x3Cscript\x3E
You can use this http://www.htmlescape.net/stringescape_tool.html
If possible paste your script here .. there might be some other escaping issue ...
Thanks @Mizan, for your help.
Here is the script i am trying to add:
getFieldById("summary").setHelpText ("\x3Cscript\x3Esssdadsasda;\x3C\x2Fscript\x3E")
This is the error i am getting (before saving)
Compilation failure: startup failed: Script1.groovy: 3: unexpected char: '\' @ line 3, column 39. getFieldById("summary").setHelpText ("\x3Cscript\x3Esssdadsasda;\x3C\x2Fscript\x3E") ^ 1 error |
ok , dont escape the < > characters let it be <script> ... what is sssdadsasda ? the escaping issue might be in your script and not the <script> tag .. What is the real script you are trying to apply ?
Also you will need some imports try the below script
import com.onresolve.jira.groovy.user.FieldBehaviours
import com.onresolve.jira.groovy.user.FormField
getFieldById("summary").setHelpText ("<script>sssdadsasda;</script>")
