Javascript not working in custom fields
Mohin Uddin
Hi Expert,
I am using JIRA version 4.0.2 currently I am using some java script code to one custom field.At before It worked fine but now it does not working.
Could you please check this issue and let us know the solution.
codes are given below:
<script type="text/javascript">
if (typeof(CustomTextFiller) == "undefined") {
var CustomTextFiller = new Class({
Implements: Options,
options: {
textareaId: "",
values:[]
initialize: function (options) {
this.setOptions(options);
this.textarea = document.id(this.options.textareaId);
if (!this.textarea && console)
console.log("CustomTextFiller[" + this.options.textareaId + "]: Textarea not found!");
if (this.options.values.length == 0 && console)
console.log("CustomTextFiller[" + this.options.textareaId + "]: No values specified!");
var isNewRecord = true;
var formTitles = $$("h3.formtitle");
for (var i = 0; i < formTitles.length; i++) {
if (formTitles[i].get("text").trim() == "Edit Issue") {
isNewRecord = false;
break;
if (!isNewRecord)
console.log("CustomTextFiller[" + this.options.textareaId + "]: Not a redo request!");
if (this.textarea && this.options.values.length > 0 && isNewRecord) {
this.cycle = this.getCycle();
this.appendLine("[BEGIN_CYCLE_" + this.cycle + "]");
for (var i = 0; i < this.options.values.length; i++) {
var item = this.options.values[i];
var x = item.split(/:0:/g);
var key = x[0];
var value = x.length > 1 ? x[1] : "Undefined";
var div = this.createCheckboxDiv(key, value);
div.inject(this.textarea, "before");
var otherDiv = this.createOtherCheckboxTextboxDiv();
otherDiv.inject(this.textarea, "before");
if (console)
console.log("CustomTextFiller[" + this.options.textareaId + "]: Loaded successfully.");
} else {
if (console)
console.log("CustomTextFiller[" + this.options.textareaId + "]: Not loaded.");
getCycle: function(){
var cycle = -1;
if (this.textarea) {
var regex =  /\[BEGIN_CYCLE_(\d*)\]/g;
var match = null;
while((match = regex.exec(this.textarea.value)) != null)
var x = parseInt(match[1], 10);
if (typeof(x) == "number" && x > cycle) {
cycle = x;
if (console)
console.log("CustomTextFiller[" + this.options.textareaId + "]: Update cycle to " + x + ".");
return cycle + 1;
createCheckboxDiv: function(key, value) {
var checkbox = new Element("input", {
type: "checkbox",
id: this.options.textareaId + "_" + key,
value: value
checkbox.set("key", key);
checkbox.set("value", value);
checkbox.addEvent("click", function(){
var line = checkbox.get("key") + ":" + this.cycle + ":" + checkbox.get("value");
if (checkbox.checked)
this.appendLine(line);
else
this.removeLine(line);
this.textarea.focus();
this.checkbox.focus();
}.bind(this));
var label = new Element("label", {
"for" : this.options.textareaId + "_" + key,
html : value
var div = new Element("div");
div.grab(checkbox);
div.appendText(" ");
div.grab(label);
return div;
createOtherCheckboxTextboxDiv: function() {
type: "checkbox",
id: this.options.textareaId + "_OTHER",
value: "OTHER"
var textbox = new Element("input", {
type: "text",
id: this.options.textareaId + "_OTHER_value"
checkbox.addEvent("click", function(e){
if (textbox.value.trim().length == 0) {
alert("Please enter problem description first!");
e.stop();
} else {
var line = "OTHER:" + this.cycle + ":" + textbox.get("value");
if (checkbox.checked) {
textbox.setProperty("readonly", "readonly")
} else {
textbox.setProperty("readonly", "")
}.bind(this));
"for" : this.options.textareaId + "_OTHER",
html : "Others"
div.grab(checkbox);
div.grab(label);
div.grab(textbox);
return div;
appendLine: function(line){
var lb = window.ie ? "\r\n" : "\n";
if (this.textarea.value.trim().length > 0)
this.textarea.value = this.textarea.value.trim() + lb + line;
else
this.textarea.value = line;
if (console)
console.log("CustomTextFiller[" + this.options.textareaId + "]: Append \"" + line + "\".");
removeLine: function(line){
if (this.textarea && this.textarea.value.trim().length > 0) {
var regexText = window.ie ? "\r\n" + line : "\n" + line;
var regex = new RegExp(regexText.escapeRegExp(), "g");
this.textarea.value = this.textarea.value.trim().replace(regex, "");
if (console)
console.log("CustomTextFiller[" + this.options.textareaId + "]: Remove \"" + line + "\".");
window.addEvent("domready", function() {
var customfield_11695 = new CustomTextFiller({
textareaId: "customfield_11695",
values:[
"New/Changed Functionality:0:New/Changed Functionality",
"Creative Asset Delay:0:Creative Asset Delay",
"GMIT:0:GMIT",
"Bug Fixing:0:Bug Fixing",
"Production Capacity:0:Production Capacity",
"Brand/Legal delay:0:Brand/Legal delay"
</script><font color="red">Please specify the change requirements/details (at every revision round) in the comments box below.</font>
Mohin
Mohin Uddin
Thanks Boris Georgiev.We didn't anu kind of change this code at before.
Mohin Uddin
the error says "Uncaught ReferenceError: Class is not defined"
Boris Georgiev [Appfire]
March 17, 2014
Obviously there is no Class Javascript object. What have you changed before this code stopped working? Have you changed the version of JIRA or something else in the code ?
Mohin Uddin
Thnx for the information.
I have already running in the Chrome browser console and find a syntax error.
So,that how can I resolve this?
March 17, 2014
What does the error says ?
Mohin Uddin
We are using the above javascript code for six check box fields and those were appearing perfectly currently those fields are not working.
March 17, 2014
Are there any JS errors in the borwser console? Try running this with Chrome and look at the Console (F12)
March 16, 2014
Would you give some more information - What exactly isn't working as this is pretty long JS snippet :)
