Jira 10.3.7 - Workflow transition dialog Enter key not working
daheeahn
August 26, 2025
After upgrading to Jira Software v10.3.7 (build: 10030007-sha1:a563685), I noticed that in the workflow transition dialog, pressing the Enter key no longer submits the transition.
Previously, hitting Enter would trigger the transition and move to the next workflow step, but now it only works if I explicitly click the transition button with the mouse.
I would like to confirm:
Is this an intentional change in Jira 10.3.7?
Or is it a bug/regression that should still allow Enter key submission?
Is there any admin/system setting to restore the previous behavior?
Has anyone else experienced this issue after upgrading to Jira 10.3.7? Any workarounds or confirmation would be appreciated.
Thanks in advance!
Benjamin
HI @daheeahn
Welcome to the community. Based on the release note on 10.3.7, there was nothing introduce in relation to this. Nor is there any fixes in the next two 10.3.x release related to this. You may want to raise a ticket with Atlassian to investigate further in case there is a bug introduce?
Release note documentation can be found here:
https://confluence.atlassian.com/jirasoftware/issues-resolved-in-10-3-7-1574503427.html
