Hi, We have installed Jira in 4.4.5 successfully compelted the 4 steps of setup.
Then when we tried to login to Jira. It says - Jira Startup Failed.
The following plugins are required by JIRA, but have not been started:
Please let me know how can this be resolved.
harish.
Hi Harish,
Hmm, it seems that this could be related to the caches of your JIRA instance. You will have to remove and recreate them, which you can do with the following steps :
Joe
Hi Joe,
I have followed the below steps:
1. Stopped Jira.
2. Deleted the contents of 'Work' folder. There was a folder called 'Catalina' inside 'Work' folder.
3. There are no files as '.osgi-plugins' and the '.bundled-plugins' in the Plugins folder. ( inside Jira home folder).
4. Started Jira.
But stil the Jira Startup Faied error persists.
Please guide.
Harish
Hi again harish...
i can't believe this...could you please use a cmd like "ls -la ${path_to_your_JIRAHOME}/plugins" ?
these are hidden folders. i assume you're on a linux host and just missed the . in front of the directory name :)
could you please have a look at this again?
Hello
I have the same question. I am on Jira 8 and it does not have the folders in question. I have a installed-plugins with all the plugins for my instance. I am also having an jira start after a system restore. I can't delete the catalina folder inside of the work folder as well.
Hi Harish,
In addition to Andy's and Joe's answer. Can you check with following -
Hope above steps solve your error.
HI Naren,
Thnaks for the response.
I have installed JDK 1.6.x and redirected JAVA_HOME to the new Java installed instead of JDK 1.7.x
This resolved the issue and i do not get the "Jira startup Faied" error now.
harish.
Glad it helped! :)
Hi Naren,
we are upgrading to JIRA 7.3.1 from JIRA 6.1.7
after the upgrade we are getting error "JIRA Startup Failed : Error occurred while starting Plugin Manager. Unable to install bundle caused by: Unable to install bundle"
we are using JAVA 1.8.0_92 on the server.
i tried to delete the "work" directory and the osgi-plugins' and the '.bundled-plugins.
Still the error persists. Can you please help.
Thanks and regards,
Roystine Machado.
Hi Harish,
Can you look in the logs, the above is a syptom rather than a cause, I would think the problem would be present as an ERROR or even a stack trace in the atlassian-jira.log file?
Things to check, JIRA_HOME is defined, the process JIRA runs under has appropriate permissions on that folder?
Register now
