Hello. I have writen a plugin for Jira 5.2.
Now i am about to provide some basic unit and integration tests. Therefore ive followed these instructions
https://developer.atlassian.com/display/DOCS/Run+Wired+Tests+with+the+Plugin+Test+Console
it says that there is a special test console in administration area that can be used to run wired tests in a running instance.
Click Toolbox > Plugin Test Console.
The test console appears. The console lists the type of tests it found in your project.
Im missing that in my administration area. There is no such console. I used to launch jira standalone with jira-debug. I can reproduce it anytime by creating an empty plugin skelleton using SDK. Empty plugin skeletton already has a wired test example. But there is no plugin test console available on atlas-run.
Maybe im missing something? Is there maybe a testconsole plugin that i have to install for that feature?
please help.
finaly found it.
Click on the most right toolbox button on the bottom of the screen.
still waiting for answers.
can anybody confirm that plugin test console is available in jira 5.2 by default?
still couldnt find it.
Is it maybe a jira 6 feature?
That functionality was just recently added to the sdk as a dependency. You might want to update to the latest SDK.
thanks for picking up my question.
My SDK seems to be up to date.
[INFO] [amps:update]
[INFO] SDK is already at the latest version: 4.2.0
