Jira 6.3 - workload report as per label
Paresh Gandhi
August 4, 2014
Currently it gives report as per users uncer workload tab
can i get report as per labels on ticekt?
carlos.fernandez
August 4, 2014
Probably I'm not understanding you.
The plugin measures the workload for each user. In the y axis we'll have the users and in the x axis the issues.
If you want to filter the issues per label you can set a filter in the issue navigator and then you can use it in the filter selector.
