Jira: 6.4.3: required fields do not have asterisk beside them
clem
July 27, 2015
When creating a bug the required fields do not have an asterisk beside them in a specific case.
It is when the bug is created in the pop-up screen and bug is the default type of issue.  If the window opens up with the story issue type pre-selected and we change it to bug the asterisks are beside the required fields.
Anybody else have this issue as well?  Any ideas why this is happening?
clem
August 17, 2015
It was because I had to make them mandatory in the behaviors plugin because I had a check on their value through behaviors.
They were already mandatory in the schema but apparently the behaviors plugin some how over rides the star.
codecentric AG June 15, 2016
I would recommend to use the Mandatory Field Validator of Add-On "Workflow Essentials for JIRA". See: https://marketplace.atlassian.com/plugins/de.codecentric.jira.wes/server/overview
This plugin not only shows a customized error message but also displays the asterisk next to the mandatory field.
Best regards,
Joerg
Christian Czaia _Decadis AG_
July 27, 2015
One question, are the fields mandatory by design (field configuration) or do you use the JIRA misc workflow extension or the behaviors add-on to make the filed required?
Darren Pegg
July 27, 2015
Have you tried different browsers?
