Hi community, today I noticed there was an update for Jira (7.6.3) and applied it, but after upgrade Jira from version 7.6.2 it will not start over SSL, I did rewrite server.xml and web.xml files but no luck, if I remove SSL config Jira starts normally but I need it through SSL, any idea?
in catalina.out i noticed following warning:
2018-01-09 16:10:17,599 HealthCheck:thread-3 ERROR [c.a.t.j.healthcheck.support.GadgetFeedUrlHealthCheck] An error occurred when performing the Gadget feed URL healthcheck
org.apache.http.conn.ConnectTimeoutException: Connect to jiraserver-url:8443 [jiraserver-url/ip] failed: Read timed out
09-Jan-2018 16:25:57.249 INFO [http-nio-8080-exec-5] org.apache.coyote.http11.Http11Processor.service Error parsing HTTP request header
Note: further occurrences of HTTP header parsing errors will be logged at DEBUG level.
java.lang.IllegalArgumentException: Invalid character found in method name. HTTP method names must be tokens
at org.apache.coyote.http11.Http11InputBuffer.parseRequestLine(Http11InputBuffer.java:462)
at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:667)
at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:66)
at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:802)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1410)
at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Thread.java:745)
2018-01-09 16:25:58,696 Caesium-1-3 INFO [c.a.j.p.h.service.ping.RefreshConnectionStatusJobHandler] Running RefreshConnectionStatusJobHandler...
2018-01-09 16:26:36,160 Caesium-1-3 INFO [c.a.jira.upgrade.UpgradeScheduler] Running scheduled upgrades
2018-01-09 16:26:36,181 Caesium-1-3 INFO [c.a.jira.upgrade.LoggingUpgradeService] run upgrades has started
2018-01-09 16:26:36,494 Caesium-1-3 INFO [c.a.j.upgrade.util.BuildNumberDao] Setting current build number to 76005
2018-01-09 16:26:36,515 Caesium-1-3 DEBUG [c.a.activeobjects.osgi.ActiveObjectsServiceFactory] getService bundle [com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin]
2018-01-09 16:26:36,521 Caesium-1-3 INFO [c.a.jira.upgrade.UpgradeIndexManager] There is no reindex requests of type [IMMEDIATE, DELAYED] so none will be run
2018-01-09 16:26:36,521 Caesium-1-3 INFO [c.a.j.upgrade.util.BuildNumberDao] Setting current version to 7.6.3
2018-01-09 16:26:36,529 Caesium-1-3 INFO [c.a.j.upgrade.util.BuildNumberDao] Setting downgrade version to 7.1.2
2018-01-09 16:26:36,540 Caesium-1-3 INFO [c.a.jira.upgrade.LoggingUpgradeService] run upgrades has finished successfully, and took 359 milliseconds to process.
2018-01-09 16:26:36,541 Caesium-1-3 INFO [c.a.jira.upgrade.UpgradeScheduler] JIRA upgrades completed successfully
2018-01-09 16:26:36,545 Caesium-1-3 INFO [c.a.jira.upgrade.UpgradeScheduler] Plugins upgrades completed successfully
2018-01-09 16:26:36,546 Caesium-1-3 INFO [c.a.jira.upgrade.UpgradeIndexManager] Reindexing is not allowed after this upgrade and there is no immediate reindex requests
2018-01-09 16:26:42,938 Caesium-1-4 DEBUG [c.a.activeobjects.osgi.ActiveObjectsServiceFactory] getService bundle [com.atlassian.troubleshooting.plugin-jira]
Please help,
Hi William,
From similar issues I have seen and have been reported in the Community this usually happens when the certificates were not installed in the Java Keystore. Can you verify the certificates are in the proper Java Keystore and if not please follow the Command Line Installation section of Running JIRA applications over SSL or HTTPS to add the certificates and try again.
Branden
JKS file is the same file that was working before when running version 7.6.2 and nothing changed just updated to 7.6.3 and Jira stopped working... any other advice?
keytool -list -alias jira -keystore jira.jks
jira, Jan 8, 2018, PrivateKeyEntry,
Certificate fingerprint (SHA1): E6:39:C7:6C:BB:1B:25:96:DE:AC:3D:27:78:E9:29:5E:28:3B:14:31
I reinstalled v7.6.3 from scratch (erased everything) and still not able to run Jira over SSL using working jira.jks file from previous version 7.6.2 (same server). Seems issue with version?
well after destroying everything and perform a clean install of 7.6.2 then upgrade to 7.6.3 I noticed there is a conflict with protocol:
09-Jan-2018 18:57:03.843 WARNING [main] org.apache.tomcat.util.net.SSLUtilBase.getEnabled Some of the specified [protocols] are not supported by the SSL engine and have been skipped: [[TLSv1.3]]
after removed that from config file everything works, but I lost all my info :(
